Re:Re:2019 Jimny SZ5 LED head light aim
05 Oct 2019 06:34 #214328 by Lambert
So you had the light units tilted downwards to mitigate the blinding effects of the leds on other road users but somehow this only affected the dip beam and now when you turn on the high beam it is still projecting correctly but there is no overlap between the two patterns on the road leading to a significant black spot. But because you're using the automatic headlight system it is switching to the high beam at 30 mph and you are still blinding people? I think you need to get it back to a Suzuki dealership assp and have it reset to factory and inspected for why it is putting the high beam on at 30 mph because speed shouldn't be the activation parameter for how much headlight you need. Another thing. You are not mistaking the illumination from the daylight running lights as the dip beam and then going straight to high beam are you?
  • Crumbs
05 Oct 2019 08:49 #214337 by Crumbs
Replied by Crumbs on topic 2019 Jimny SZ5 LED head light aim
Hi Lambert.
Thanks for your reply.
Its a 2019 model SZ5 aka generation 4 - I should have mentioned this at the start - sorry.
This model does have the characteristic, in the automatic headlight mode, of not allowing main beam until your speed is over 30 mph and not allowing main beam until the ambiant light falls below a specific value.
Should there be separate manual adusters for main beam and dip?
It's not like the previous Jimnys it nags you every time it can.
05 Oct 2019 09:11 #214340 by Lambert
From the pictures I have seen there are only one se5 of adjustment screws per lamp but that doesn't mean that some charlatan hasn't dug about and altered something the should have left alone. Also automatic lights are programmed for the average driver doing average things so if the auto settings doesn't do what you want and when then turn it off, cars managed just fine without auto lights for the first 110 years
  • Crumbs
05 Oct 2019 09:26 #214343 by Crumbs
Hi Lambert.
Thanks for your post.
So one adjuster for the main beam and dip on the left hadlamp and one for the main beam and dip on the right hadlamp.
Two ajusters in total?
05 Oct 2019 09:32 #214345 by Lambert
No. Up and down 1. Left and right 2. Between them they move the whole assembly as a unit. Like I said though that doesn't mean someone hasn't been inside the assembly and messed something up. It should be idiot proof but we all know they just keep producing a lower class of idiot.
  • Crumbs
05 Oct 2019 10:25 #214348 by Crumbs
Hi Lambert.
I've found the adjusters.
One at the top of the headlamp clusterand one at the bottom.
Having the beam setting checked at 12 noon.
Time to create page: 0.196 seconds
