Re:Re:Fitting the Roof Trim Kit
- Morris1
- Visitor
01 Oct 2019 18:46 #214121
by Morris1
Replied by Morris1 on topic Re:Fitting the Roof Trim Kit
I'm absolutely sure as I'm a lot of trouble with my local Suzuki dealer over this. The corners are nowhere near big enough to accommodate the trim. It's impossible to use the corners that come with the car: even my dealer can't do it!
- Morris1
- Visitor
01 Oct 2019 18:56 #214126
by Morris1
Plus the kit direct from a Suzuki dealer is £143.78. You say on your forum its £160, so perhaps the extra £16.22 is for 2 corners??
01 Oct 2019 19:03 - 01 Oct 2019 19:49 #214130
Replied by mlines on topic Fitting the Roof Trim Kit
There is something wrong there, that price to low. The original quote including the corners not needed was around £180
Edit: man maths shows you are quoting from a dealer discount band
Last edit: 01 Oct 2019 19:49 by mlines.
- Morris1
- Visitor
02 Oct 2019 08:23 #214162
by Morris1
Replied by Morris1 on topic Fitting the Roof Trim Kit
Martin the price is correct, and the new corners are needed as my dealer has now apologised for the mistake and ordered a pair. Perhaps if you had fitted these yourself you would know that new larger corners are needed.
- rsg
- Visitor
05 Jun 2020 09:33 #223279
by rsg
Replied by rsg on topic Fitting the Roof Trim Kit
Any idea what the part numbers are for the corners? I ordered the 5 parts I thought I needed and have run into the same issue.
Time to create page: 0.144 seconds
