Special Jimny Low Ratio reduction gearsets***
  • FIRSTJIMNY
26 Nov 2010 19:51 - 11 Dec 2010 17:31 #6548 by FIRSTJIMNY
Has anyone installed any drop-in reduction gearsets ***
If so, do you like them? Have you had any trouble since? What size wheel/tire combination are you running? I'd like to hear about it. Thanks
Last edit: 11 Dec 2010 17:31 by mlines. Reason: Product name removed at the request of the Manufacturer
26 Nov 2010 20:08 - 11 Dec 2010 17:33 #6549 by mlines
When I first got my Jimmy it was fitted with a special low ratio Jimny Gearset .The previous owner had to fit the transfer box back on when he sold it to me as it had ben away for "repair“.
I then ran it for a few months and it started making horrible noises, the drive chain inside was slipping. In the end i had to replace the transfer box again. Mine has had 3 Transfer Boxes I know of since the special low ratio Jimny gearset gears were fitted. Also the reduction in ratio was not low enough for my personal preference.
Last edit: 11 Dec 2010 17:33 by mlines. Reason: *** Removed product name at request of Manufacturer
  • FIRSTJIMNY
29 Nov 2010 14:39 - 11 Dec 2010 17:34 #6759 by FIRSTJIMNY
Replied by FIRSTJIMNY on topic Re: Special Jimny Low Ratio reduction gearsets***
THANKS FOR THE TIP ON THE REDUCTION GEARS. WAS SURE SORRY HEAR THAT. WILL HAVE TO GO WITH SWAPPING OUT MY CASE FOR A SAMURAI T-CASE NOW I GUESS. ANY SUGGESTIONS ON WHO DOES IT BEST?
Last edit: 11 Dec 2010 17:34 by mlines. Reason: *** Removed product name at request of Manufacturer
  • darthloachie
29 Nov 2010 15:58 #6766 by darthloachie
Replied by darthloachie on topic Re: Special Jimny Low Ratio reduction gearsets***
if you're doing it yourself then rockwatt off difflock is the cheapest and you will need to suppy a fair few parts.
An SJ410 transfer box
An SJ413 transfer box
An SJ413 centre prop
a large SJ flange to meet the front prop
SJ413 rear prop with large flanges on at least the end that meets the rear diff
Rob storr and Rob from Offroad armory will supply built rocklobsters and the props needed to fit but are dearer as they supply all/most parts
11 Dec 2010 17:39 #7347 by mlines
test
Time to create page: 0.210 seconds
