M13A - M16A
  • spj907
14 Aug 2019 17:40 #212092 by spj907
M13A - M16A was created by spj907
Hi, I'm going to swap the M13A engine in my 2000 jimny for the M16A found in the Liana, both non VTT. There are a few around, but the Question is how can you tell the vvt from the non vvt? Is it true ALL the lianas had non vvt engines? I believe i read that somewhere. Pictures showing the difference would be great but a bit of an ask!?!?
15 Aug 2019 04:17 #212108 by Lambert
Replied by Lambert on topic M13A - M16A
Vvt engines have a pronounced step/bulge in the front of the rocker cover on the left side as viewed from the front of the car. None vvt is smooth across.
  • spj907
15 Aug 2019 17:30 #212133 by spj907
Replied by spj907 on topic M13A - M16A
Brilliant, just what i needed to know. I've checked out a few pictures on line and can see the difference, thanks Lambert.
I could be back for a bit more help when i start this, but looking through some of the other posts on this subject it looks fairly straightforward....time will tell!
  • Jjbradshaw1
16 Aug 2019 11:11 #212163 by Jjbradshaw1
Replied by Jjbradshaw1 on topic M13A - M16A
Where are you based? I've got an M16A with only 27k on it that I bought last summer off a forum member. I'm looking to sell my Jimny so its not likely to get used, if you're willing to collect its yours for £200. I've even got the gaskets you'll need and a new filter as well as a liana intake.
  • spj907
16 Aug 2019 13:17 #212169 by spj907
Hi, seemed to have private messaged you!
  • Jjbradshaw1
16 Aug 2019 13:36 #212170 by Jjbradshaw1
Ah, bit of a trek for you I'm afraid unless you have courier contacts. I am up in Newcastle, NE42 6HW
Time to create page: 0.106 seconds
