Re:Rumble from back of car.
- Jedzuki
06 Jun 2019 07:07 #209697
by Jedzuki
Rumble from back of car. was created by Jedzuki
Hi everyone.
I have a 2009 Jimny. It has just started to make a loud rumble noise from the back of the car. Sounds a bit like an extractor fan above an oven! Started during a short journey yesterday, but last month I was laning on Salisbury Plain. Did go through some puddles and hit the towbar on a dropoff once.
Any suggestions on what could be wrong? Many thanks all.
06 Jun 2019 07:15 #209698
Replied by Daniel30 on topic Rumble from back of car.
If you still have the original jack in the back might need tightening up, some times they work lose and move about
- wombat
06 Jun 2019 09:03 #209702
by wombat
Replied by wombat on topic Re:Rumble from back of car.
Wheel bearing gone
Sent from my F5121 using Tapatalk
- Thank you received: 1983
06 Jun 2019 12:29 #209706
Replied by Lambert on topic Re:Rumble from back of car.
Is the noise subject to change depending upon how you are cornering? If so could be wheel bearing if not could possibly be diff carrier bearings?
- X8GGY
06 Jun 2019 13:50 #209712
Replied by X8GGY on topic Re:Rumble from back of car.
My exhaust used to rattle against my towbar bracket so I cut a triangle section out of the bracket...?
06 Jun 2019 15:58 - 06 Jun 2019 15:59 #209717
by facade
Replied by facade on topic Re:Rumble from back of car.
Mine made a rumbly bearing noise from the back, I couldn't find any problem with the back wheel bearings, and I even got a second opinion- "It is the differential, be alight for thousands of miles until it gets really bad though, then it will fail".
Swapped the diiff out and it was exactly the same. :pinch:
Few weeks later a front wheelbearing collapsed, and after I changed it, the noise from the back had gone. :ohmy:
Sounds travel.....:whistle:
Check all 4 wheelbearings.
Last edit: 06 Jun 2019 15:59 by facade.
Time to create page: 0.246 seconds
