anti roll bar D bushes
- invincible
02 Jun 2019 12:26 #209466
by invincible
anti roll bar D bushes was created by invincible
hello all, i had an advisory on MOT that the anti roll bar D bushes had play in them, i was thinking of replacing them but after reading up
some folk take the roll bar off completely , so then thought its not worth bothering if they only have a few mill play ? i,m not exactly cornering at 80mph, am i thinking right on this? whats folks thoughts ? cheers Liam.
02 Jun 2019 15:20 #209476
Replied by jackonlyjack on topic anti roll bar D bushes
Removed mine 3 years ago
You get used to how it feels
If you're running a suspension lift you will need extended brake lines
to cope with axle articulation off road
02 Jun 2019 17:38 #209483
Replied by Riccy on topic anti roll bar D bushes
Some MOT testers notice its absence. Not sure what that results in, but if you take it off it might be best to blank off the bolt holes and paint it to look like theres never been one on
03 Jun 2019 20:39 #209565
by Scimike
Replied by Scimike on topic anti roll bar D bushes
They are as cheap as chips even for genuine Suzuki ones and not hard to replace, you have to remove more bits to take the bar off.
So if you are mostly on road it's going to handle better with it.
If you have a lift, big tyres and want articulation then take it off.
The following user(s) said Thank You: invincible
- Thank you received: 2001
04 Jun 2019 04:33 #209571
Replied by Lambert on topic anti roll bar D bushes
When I had the 90 it was a thing to remove the anti roll bars from them, so I did because I was young and foolish. They were back on within the weekend. Didn't like feeling like I was going to fall off the road with every bend. As has been said, new ones are cheap and plentiful and easy to replace.
- X8GGY
04 Jun 2019 05:37 - 04 Jun 2019 05:39 #209577
Replied by X8GGY on topic anti roll bar D bushes
Last edit: 04 Jun 2019 05:39 by X8GGY.
Time to create page: 0.178 seconds
