supercherger noise jimny 2017 gen 3
  • barnsley john
31 May 2019 19:51 #209341 by barnsley john
Replied by barnsley john on topic supercherger noise jimny 2017 gen 3
am I getting mistaken then from a intercooler not supercharger
the fan is what I thought is it what would have been on cars before electric fans ie my old ford capri thanks john
31 May 2019 19:53 #209342 by Riccy
On the european diesel jimnys the bonnet scoop might be for an intercooler, likley just a vent on a petrol.
There is a turbo kit on aliexpress for the jimny, that would make use of the scoop with a nice intercooler :whistle:
31 May 2019 19:56 #209346 by Lambert
When you look at the mouth of the scoop it is blanked off with a black plastic trim.
31 May 2019 19:58 #209347 by Keithy
facade wrote: The fan roars, more so when the engine is cold (all viscous fans do, I never figured that out, you'd expect it not to drive when it is cold, maybe the fluid takes a while to get the right idea?)
A very interesting device....much maligned and works a treat.
The following user(s) said Thank You: facade
31 May 2019 20:05 #209348 by Keithy
barnsley john wrote: am I getting mistaken then from a intercooler not supercharger
Not sure what you mean....an intercooler cools the air before it gets compressed again by another compressor.....turbo feeding a bigger turbo etc....an aftercooler is on an engine equipped with a single turbo or supercharger....."compressor" in it's exemplar definition.......inanimate objects are usually quiet until acted on by outside forces.....rocks and branches lol.....then they hiss and have fits.
31 May 2019 20:53 #209354 by facade
Ah, most likely the fluid was all in the outside part as the engine would have been hot when it was put away, so it takes a while to pump it all back to the reservoir, I was right, it takes a while for it to get the idea :)
Time to create page: 0.509 seconds
