Suspension squeek
28 May 2019 18:52 #209143 by mlines
Suspension squeek was created by mlines
I have an annoying squeek, like a bird twittering. It occurs on a flat road ie when the suspension is doing nothing. Large flexes and bumps do not have an issue. So it's the spring moving against the rubber top seat or a bush squeeking on its bolt. I should be able to chase it down with WD40, but is there a better squeak ointment?
  • Cremator1
28 May 2019 18:58 #209144 by Cremator1
Replied by Cremator1 on topic Suspension squeek
Duck oil is good can’t see why people bang on about wd40 to be honest it’s a water dispersant great for that
28 May 2019 19:00 #209145 by mlines
Replied by mlines on topic Re:Suspension squeek
I am not suggesting WD40 as the solution, just the detection method ?
  • Cremator1
28 May 2019 19:03 #209146 by Cremator1
Replied by Cremator1 on topic Re:Suspension squeek
Yes I no you was lots of other products out there better than wd to use have a look at duck oil
28 May 2019 19:17 - 28 May 2019 19:22 #209147 by Jezz
Replied by Jezz on topic Suspension squeek
Silicone lubricant spray is good for that sort of thing. Halfrauds sell it. :)
It's been fettled just a tad.
Last edit: 28 May 2019 19:22 by Jezz. Reason: spelling
28 May 2019 20:09 - 28 May 2019 20:11 #209150 by Scimike
Replied by Scimike on topic Suspension squeek
+1 for the silicone lubricant especially if you have Polly bush fitted, tends not to attack the bush. May need to spray each bush in turn and flex the suspension to work it in if you want to locate the culprit, or spray them all and find some rough ground to give it all a good flex.
Last edit: 28 May 2019 20:11 by Scimike.
