Jimny 3 Tach/RPM wire
- Jim Jim
18 May 2019 13:16 #208260
by Jim Jim
Jimny 3 Tach/RPM wire was created by Jim Jim
Hi Guys,
I am trying to locate the Tach/RPM wire on my 1999 Jimny, looked all over but so many links are broken and pics missing, anyone knows which wire it is?
The other option is to pull the cluster, measure the RMP input and then trace it all the way back which is a longer process.
Thanks Guys.
Thanks Guys.
18 May 2019 15:32 #208268
by Keithy
Replied by Keithy on topic Jimny 3 Tach/RPM wire
The following user(s) said Thank You: Jim Jim
- Jim Jim
18 May 2019 16:21 #208273
by Jim Jim
Replied by Jim Jim on topic Jimny 3 Tach/RPM wire
Hi Keithy,
Thanks for the diagram but when I enlarge it, its all blurry, can you please upload a larger diagram?
Thanks.
Thanks.
19 May 2019 16:07 #208381
by Keithy
I see what you mean....forum software ruins it lol.... It's the brown wire on pin 9.....I had to fit a 1k pullup to it to make a megasquirt show rpm....hth
- Jim Jim
20 May 2019 12:31 #208477
by Jim Jim
Hi Keithy,
Thanks for the clarification. Its nice to see someone install a stand along ECU in the Jimny, man you guys did a lot with these, I am guessing you went FI.
I need the RPM input for the remote start sequence, I will see if the remote start module sees the input or if I have to put in a 1K pull up resistor too, will update you when I get to that point.
Thanks for your help Keithy.
Have a great day.
Have a great day.
20 May 2019 21:09 #208542
by Keithy
Time to create page: 0.440 seconds
