Another death wobble diagnosis help!
03 Apr 2019 13:31 #205473 by Wailin
I reduced the pressure down to 23 and 26. Made no difference to wobble but did affect road handling. It feels less steady and more bouncy at 50-60mph.
I'll have a look at the panhard bushes and check the tracking rod ends again.
03 Apr 2019 20:09 #205500 by Wailin
Guys should there be play in the track rod end in the forward/back direction? There is no lateral play but I was able to wiggle it back and forth as seen in the pics:
03 Apr 2019 22:00 #205505 by jackonlyjack
No buy new ones :)
Change all 4 if it's within your budget
And any you take off feel good keep them as spares ;)
I hate to state the obvious 2 left hand thread 2 right hand
Jack
The following user(s) said Thank You: Wailin
03 Apr 2019 23:02 - 03 Apr 2019 23:12 #205507 by Scimike
Not wanting to disagree, changing your ball joints may well improve your wobble, it's a complex mix of things.
But ball joints can move as shown in the photos, it's a ball in a socket that allows it to rotate as shown. It should be stiff to move (not sloppy) and have no lateral or vertical movement in relation to the pivot arm to which it is connected, but it can rotate as the pictures show. What the picture can not show is any play in the movement, it's a feel thing.
Change them if you can't find anything else with movement (check you kingpin bearings) or if you are not sure what a good ball joint should feel like.
Last edit: 03 Apr 2019 23:12 by Scimike.
The following user(s) said Thank You: Lambert, Wailin
04 Apr 2019 08:08 - 04 Apr 2019 08:10 #205516 by Scimike
Also to repeat what Jack has already said...
My Jimny had slight wobble between 45 _50 but I am on standard size tyres, so I masked the issue with a steering damper. No detectable play in the wheels at all (passed MOT) and no signs of any leaks at the swivels. Fast forward 6 months and I can now feel play in the passenger side kingpin bearing, so they are shot, BUT still no signs of a leak on the swivel. So they don't all leak even when shot.
The correct preload on these bearings is instrumental in controlling wobble, so worn (but not loose) bearings can be a factor, especially with bigger tyres (larger mass).
Last edit: 04 Apr 2019 08:10 by Scimike.
04 Apr 2019 09:24 - 04 Apr 2019 09:26 #205523 by Wailin
Thanks for helpful advice folks. I am aware that no seepage doesn't mean kingpin bearings are not shot. But when i jacked it up there was no play in the wheels at all, in any direction.
I have new brake discs and pads ordered from jimnybits as i think they are warped. When rotating the wheels freely i kept getting resistance in certain parts of the rotation and i could hear the pads rubbing off the discs. Could be part of the issue too?
Last edit: 04 Apr 2019 09:26 by Wailin. Reason: Grammer
Time to create page: 0.385 seconds
