Re:light steering - trying to fix
  • NineCherries
7 years 8 months ago #204278 by NineCherries
light steering - trying to fix was created by NineCherries
evening folks
i tried searching the forum first but any light steering posts related to lifed Jimnys that need caster correction.
The steering on my jim is getting very light/ wooly. I can't really explain it any better im afraid, no wobble, no vibratiation, just very light feeling and vague with lots of corrective steering input needed. Now i recently started a new job so i do a few more motorway miles than i did before but its not a happy Jimny (or driver) on a motorway. Im aware because of the narrow track you can be tramlined into the worn tracks on the motorway but the steering wheel feels detached at times, not nice. Crosswinds are a nightmare to drive in.
With the car stationary I can wobble the steering wheel and see the road wheel moving, no clunks, not notchy and i wouldn't say excessive amounts of steering input before the wheel moves. Ive been driving my Jimny for over 4 years and cant say ive notice it feeling so light before BUT i didnt normally run at motorway speeds
Do you think its just always been like this and ive never noticed? its a different road im diving on now so its poss its more worn and highlighting the issues.
So heres a list of the maintenance i've carried out over the past year or so,
standard height with monroe shocks that are only 6 monthe old. (could the springs be past it?)
general grabber tyres (4 year old but plenty of tread)
both wheel bearings done a year ago along with king pin bearings (and shimmed where needed)
manual hubs fitted 6months ago
rear engine(gearboxmount) done 11 months ago
both front calipers done 6 weeks ago
ive checked for play on steeing rod and panhard rod both seem ok,
no play on wheels/hubs
tyre pressures ok
with all the work ive done to the front hubs i suppose it is worth checking the toe in is still correct (not tried to check that yet) and ill be giving it a good going over this weekend so looking for some help identifying any specific areas to look at.
thanks for taking time to read through this lengthy post.
Tony
7 years 8 months ago #204283 by Max Headroom
I don't know if this suggestion will help as I don't have enough Jimny experience under my belt, but certainly on cars that had the old Armstrong lever-arm type shock absorbers, if the shocks lost their oil or the vane bacame worn (an internal leak), the car would give you a "floaty" sensation as you drove along which is slightly like what you described.
This was particularly noticeable if it was front shocks that had failed.
Have the front shocks failed, or started to?
The following user(s) said Thank You: NineCherries
  • NineCherries
7 years 8 months ago #204285 by NineCherries
Replied by NineCherries on topic Re:light steering - trying to fix
I’ll check again but I really hope not as they have only been in the car 6 months and only about 3000 miles (all 4 shocks replaced)
I’ve been wondering if it could even be worn bushes in the caster arms?
7 years 8 months ago #204289 by Lambert
It's possible that the panhards bushes are tired but I would expect there to be a wobble it that was it. The tracking could easily explain the vagueness but in the first instance I would be checking the tyre pressures on multiple gauges to be certain they are correct.
Time to create page: 0.095 seconds
Powered by Kunena Forum
