Hi people having difficulty with with my 2003 mj13a, elm came P0335
- Scooter
07 Jan 2019 14:07 - 07 Jan 2019 14:21 #200125
by Scooter
Hi people having difficulty with with my 2003 mj13a, elm came P0335 was created by Scooter
EML light came on when code read on snap on solus P0335 code came up crank shaft sensor replaced camshaft sensor still the same replaced camshaft sensor still the same replaced timing chain still the same replaced starter motor and alternator still the same what it does is you can start it clear the code and it stays off when you restart the code come straight back up again driving me absolute crackers I have checked voltages and those are both crank and cam sensors all good as anybody out there a wiring diagram for the ECU please or any help driving me mad
Last edit: 07 Jan 2019 14:21 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
07 Jan 2019 20:08 #200144
by kbike
2018 Jimny auto:allegedly the last "old" auto registered UK.
Replied by kbike on topic Hi people having difficulty with with my 2003 mj13a, elm came P0335
"P0335 code came up crank shaft sensor replaced camshaft sensor still the same replaced camshaft sensor still the same "
Is this a"typo",camshaft sensor fault range is P0340-0349.Believe ECU wiring may be in www.suzuki4x4.net/manual/jimny/99512_81A20_015.pdf but looks like it may take time to digest.
Attachment not found
- Scooter
07 Jan 2019 20:12 #200145
by Scooter
Replied by Scooter on topic Hi people having difficulty with with my 2003 mj13a, elm came P0335
Sorry yes. I’ve replaced both crank and cam shaft sensors
I’ll take a look at the ECU wiring link. Thank you. Much appreciated.
Time to create page: 0.222 seconds
