Sluggish up hills, blocked cat?
21 Dec 2018 23:37 #199292 by jjabbot
Anyone have any thoughts on why my 2002 Jimny would be sluggish up hills? Won't rev beyond 3000 rpm, and sounds pained doing it. Read online it might be a blocked cat? Just changed the front lambda sensor after it triggered the eml, but that hasn't improved things. Thoughts?
Sent from my Pixel using Tapatalk
22 Dec 2018 07:45 #199296 by mlines
Sounds like a possible blocked cat
  • JustCallMeRick
22 Dec 2018 08:19 - 22 Dec 2018 08:20 #199298 by JustCallMeRick
Replied by JustCallMeRick on topic Sluggish up hills, blocked cat?
Flexi cam trough Lambda sensor hole to inspect the top of the cat. It should be a nice honycomb structure.
Last edit: 22 Dec 2018 08:20 by JustCallMeRick.
22 Dec 2018 11:01 #199307 by Max Headroom
Not something daft like blocked air-filter is it?
I changed a brand new paper filter for a K&N job and was totally surprised at the difference it made.
22 Dec 2018 11:19 #199310 by yakuza
JustCallMeRick wrote: Flexi cam trough Lambda sensor hole to inspect the top of the cat. It should be a nice honycomb structure.
Mine did not look to bad actually but the improvement when changed was awesome! Still amazed by the improvement 6 months later.
I tried flushing it with water first which gave a small improvement.
Mine is the VVT not sure if the older ones have the two-cat system but the first one in the manifold often disintegrates and the dust and debris from it clutters up the second one.
I have completely removed the first one and use a OEM cat for up to 2.0 liter engines where the number two cat was.
It has produced two fault codes for ineffective cat in cold weather but just delete those and its ok.
Bought mine at Biltema, it is a kind of Halfords i guess.
03 Jan 2019 18:56 #199977 by jjabbot
An update. Cat changed an sluggishness up hills gone!
Time to create page: 0.220 seconds
