Longfield HD halfshafts, need to weld studs?
  • OlaGB
25 Nov 2018 20:39 #198162 by OlaGB
A question to you guys that has installed these HD halfshafts, are you having any issues with the studs rotating in theire splines, so you had to weld them?
I saw a post, cant remember who, that had to weld them after they had started rotating during wheel change. But i dont know if this is a common issue, only on first batch, or if i should do it to mine as well. Bought them 3 months ago, installing them now on wednesday/thursday.
Front and rear.
26 Nov 2018 06:17 #198166 by X8GGY
That was me... I've had two wheel studs twist out of one of my TrailGear HD rear shafts...
I'm not sure if this is an isolated case though? As I've not read of any other problems?
Dave
26 Nov 2018 07:30 #198169 by X8GGY
Interestingly though, and if it inspires more confidence, I've recently fitted another pair in a new (secret winter) project -
And I haven't welded these studs on... I figure this one won't get so much abuse as S200KYS, and this one has drum brakes so the flanges are protected from the elements (S200KYS has a disk brake conversion so the flanges are open to the elements?)
Dave
  • OlaGB
26 Nov 2018 11:08 #198173 by OlaGB
S200KYS wrote: Interestingly though, and if it inspires more confidence, I've recently fitted another pair in a new (secret winter) project -
Dave
Thanks Dave! I`m also still running drums, and will keep on doing that.
I guess they should be fine then, if you havent heard about any others.. Youve been around here alot longer than me, so you would know i guess :)
Another question , have you installed front HD axles as well?
I`m wondering how to install shafts into the knuckles.. Just shove them in till they click in place?
I thought thats how it was done, but in the knuckle box, theres some C clips iin a bag... And the knuckles are full of grease.. So i thought i should ask :)
26 Nov 2018 12:57 #198174 by Riccy
The c clips on on the ends of the stub axles before fitting into the CV. Don’t try it without them, I did and it caused a embarrassing 3wd issue when out laning :-(
Other than that, shove em in. Pretty easy.
  • OlaGB
26 Nov 2018 13:32 #198175 by OlaGB
Riccy wrote: The c clips on on the ends of the stub axles before fitting into the CV. Don’t try it without them, I did and it caused a embarrassing 3wd issue when out laning :-(
C-clips on, shove in, got it! Thanks!
Just out of curiosity, is it some mechanism inside the knuckle that locks onto/over the C-clip?
Time to create page: 0.793 seconds
