Radio Aerial
04 Nov 2018 16:57 #197299 by jjabbot
Radio Aerial was created by jjabbot
I've managed to snap the second external aerial on my 2002 hard top Jimny!
I'm wondering if anyone has found a successful alternative, either a non suzuki replacement that isn't metal, or an internal solution, stuck to the windscreen?
I read someone had come up with a solution that used the wire demister in the rear glass door! Has anyone tried that?
Would be good to avoid an external aerial as it will only get broken again, as I'm in and out of the woods.
All suggestions gratefully received. Just looking for fm reception don't need DAB .
Thanks John
Sent from my Pixel using Tapatalk
04 Nov 2018 17:56 #197301 by jackonlyjack
Replied by jackonlyjack on topic Radio Aerial
I had one like this it worked fine
eBay item number:173310682387
The following user(s) said Thank You: jjabbot
04 Nov 2018 17:58 - 04 Nov 2018 18:00 #197302 by Riccy
Replied by Riccy on topic Radio Aerial
There was a recent post about using a splitter for the CB aerial for FM radio. Cant remember who though :unsure:
Old Ford Sierra's used to have the rear demist aerial thing. It was a box in the boot somewhere, Must be something like that available on ebay or similar?
EDIT:
Forgot to say, I have a DAB radio aerial sticker thing on the windscreen. works ok, but not as well as the roof one on the work van. doesnt do FM however.
Last edit: 04 Nov 2018 18:00 by Riccy.
04 Nov 2018 18:33 #197305 by ahtr
Replied by ahtr on topic Radio Aerial
Riccy wrote: There was a recent post about using a splitter for the CB aerial for FM radio. Cant remember who though :unsure:
I'm using one of these in my Jimny through cb aerial.
If you don't have a cb, something like this from Halfords?
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
04 Nov 2018 19:08 #197306 by jjabbot
Replied by jjabbot on topic Re:Radio Aerial
Sadly I can't see the items you refer to. Thanks for your reply, is there another way you can point me at the links?
04 Nov 2018 19:09 #197307 by jjabbot
Thanks, I'll have a search.
Time to create page: 0.205 seconds
