What Brand of Rear Wiper Blade?
- theoldseacaptain
- Junior Member
- Thank you received: 7
30 Aug 2018 12:05 #195562
by theoldseacaptain
Sadly jimny-less but still got the bug!
What Brand of Rear Wiper Blade? was created by theoldseacaptain
Not the exactly the most technical of topic!
I have recently replaced my unbranded rear wiper blade with a Bosch 11" universal blade, however it seems that the blade is too rigid to follow the slight curve of the rear window!! Ive compared it to a Valeo blade, which seems to be the same and obviously don't want to go buying more blades that will be the same......
What brand of rear wiper blade works??
Thanks
Thanks
- Zee Zee Top
30 Aug 2018 14:09 #195572
by Zee Zee Top
Replied by Zee Zee Top on topic What Brand of Rear Wiper Blade?
I had the same problem. The only wiper I found that would clear the screen properly was a genuine Suzuki one. Not expensive and no frustration.
30 Aug 2018 14:32 #195573
Replied by jackonlyjack on topic What Brand of Rear Wiper Blade?
Mine as a Peugeot 107 silicone blade on
30 Aug 2018 15:26 #195575
Replied by yakuza on topic What Brand of Rear Wiper Blade?
I never use my rear wipers on any car..
They only scratch the windows as the rear collects too much sand.
I have been thinking about removing it and use the hole for a CB antenna.
Sorry if this i is too off topic
30 Aug 2018 21:24 - 30 Aug 2018 21:26 #195588
by Scimike
Replied by Scimike on topic What Brand of Rear Wiper Blade?
I replaced mine with one from Halfords. Can't remember if it was Bosch or Halfords own brand (Velo), but which ever it has no issues following the very slight curve on the rear window. I do recall I had to try a few as the one listed on the computer system did not fit the arm, it was too wide.
Trial and error with the staff found one that fitted.
You can also try it outside the store and if you are not happy with the way it follows the window shape ask for a refund.
Last edit: 30 Aug 2018 21:26 by Scimike.
- theoldseacaptain
- Junior Member
31 Aug 2018 16:29 #195616
by theoldseacaptain
Replied by theoldseacaptain on topic What Brand of Rear Wiper Blade?
The Bosch one and trail fit the Valeo was Halfords, so maybe changed supplier / specs unfortunately.
Did you need to fit a 107 arm Jack? From what I found its a special blade??
Failing that it looks like it will be a trip to Suzuki!
