What corrections needed for 40mm lift?
  • ramonmaruko
  • Visitor
  • Visitor
28 Aug 2018 08:41 #195482 by ramonmaruko
Replied by ramonmaruko on topic What corrections needed for 40mm lift?
Thank you for checking. Yes, just the OME lift kit with the caster correction bushes.
Anyway, I tried going to 50km/h to 80km/h again in a good condition highway (Cebu South Coastal Road) last night and I didn't experience the "wavy" driving. But in another road in the same night, I encountered the "wavy" driving. So this steering problem might be caused by road imperfections. The death wobble (around 80km/h - 90km/h) is still there but I think this is another issue.
  • GRAYWOLF
  • Visitor
  • Visitor
28 Aug 2018 14:56 #195495 by GRAYWOLF
Replied by GRAYWOLF on topic What corrections needed for 40mm lift?
With regard to the so called 'death wobble'
I also experienced this, after fitting slightly bigger tyres(215.70 x15.
Checked track rod ends, kingpins..etc..etc..after trying all the usual, i eventually followed advice from a guy on here, and fitted balancing beads to my front tyres..problem solved, no more wobble, these really DO work..i had tried getting wheels rebalanced also, no difference.
However popped these into my front tyres..brilliant..no more wobble or vibes..worth the money..and, they arent expensive..
28 Aug 2018 16:40 #195497 by jackonlyjack
+1 on the balancing beads work just fine in my 225/75/16'S got mine from Devon 4x4
The following user(s) said Thank You: GRAYWOLF
29 Aug 2018 01:15 #195512 by zukebob
Checked my coils and, as I expected, 2 of them are the same as yours. Certainly not a source of your steering problem.
I don't have any experience with the balancing beads (although I've been tempted to try) but would agree with graywolf and jackonlyjack that the place to start would be with wheel balance. If that doesn't work, then you may want to take it somewhere that can do a thorough alignment check.
The following user(s) said Thank You: ramonmaruko
  • ramonmaruko
  • Visitor
  • Visitor
29 Aug 2018 03:24 #195513 by ramonmaruko
Thank you for checking it Bob.
I'll have the wheels balanced and will do an alignment check to see if it solves the problem. As for the balancing beads, I'll read more about it.
As for the LSPV, shouldn't it be located here? https://photos.app.goo.gl/p4Jmed1bBmG6AW9A8 I see no spring attached. I'll cross reference it with the service manual to verify tomorrow. I'm assuming that the "old" service manuals for the SN413 still applies to the JB43?
29 Aug 2018 06:49 #195516 by zukebob
Sorry. I saw your question on the bracket earlier and was going to answer it but I became focused on the suspension and forgot. I'm not sure if any of the post 2015 Jimnys came with the bracket. The 2015s don't have it. The picture you show is the same as mine (without alteration).
Time to create page: 0.164 seconds
