Changing the kingpin/swivel bearings - questions
- 2013gary
- Visitor
04 Jul 2018 12:45 - 04 Jul 2018 12:47 #193958
by 2013gary
Replied by 2013gary on topic Changing the kingpin/swivel bearings - questions
Just put mine back together and the wobble is still just as bad as it was before. I suppose the next step is to do the kingpins on the other side and see if that makes a difference. The seals are currently out of stock on the BigJimny store so I'll have to wait
Last edit: 04 Jul 2018 12:47 by 2013gary.
- theoldseacaptain
- Junior Member
- Thank you received: 7
04 Jul 2018 14:13 #193959
by theoldseacaptain
Sadly jimny-less but still got the bug!
Replied by theoldseacaptain on topic Changing the kingpin/swivel bearings - questions
I had a similar issue a few months ago - changed all kingpins without much improvement. In the end it was new brake discs that cured it!
- Dano0404
- Visitor
04 Jul 2018 21:34 #193973
by Dano0404
Replied by Dano0404 on topic Changing the kingpin/swivel bearings - questions
Done the other side to day still a very slight wobble but think I can live with it for now. The disk guard rubbed as well witch makes a hell of a noise the wheel brace was perfect for bending it back.
- 2013gary
- Visitor
05 Jul 2018 08:02 #193992
by 2013gary
Brake discs are an easy and cheap fix, but from what I've read on here the brake discs only cause wobble under braking. Was that the case with yours, or did it wobble when you weren't braking?
theoldseacaptain wrote: I had a similar issue a few months ago - changed all kingpins without much improvement. In the end it was new brake discs that cured it!
I've had this problem after changing a track rod end, I must have moved the guard while swinging on the the top nut or something.Dano0404 wrote: Done the other side to day still a very slight wobble but think I can live with it for now. The disk guard rubbed as well witch makes a hell of a noise the wheel brace was perfect for bending it back.
- theoldseacaptain
- Junior Member
05 Jul 2018 10:51 #194000
by theoldseacaptain
Yes, mine wobbled all the time which led me to the Kingpin bearings first....
- 2013gary
- Visitor
05 Jul 2018 10:55 - 05 Jul 2018 10:55 #194001
by 2013gary
Interesting to know, thanks. I've just ordered new track rod ends, which I plan to fit before getting the wheel alignment looked at. If that doesn't work then I'll try new brake discs.
Last edit: 05 Jul 2018 10:55 by 2013gary.
Time to create page: 0.144 seconds
