Front fog lamps.
03 Apr 2018 22:53 - 03 Apr 2018 22:54 #191273
by Scimike
Replied by Scimike on topic Re:Front fog lamps.
Max,
I totally agree that the future is LED and I would still like to fit them again to my Series Landy. The big benefit was mega light output and reduced load on the ageing switch gear, in particular the pressure activated stop switch which is prone to failure. Looks like I fell foul of the cheap imports, so any suppliers of quality products should be highlighted by those that have had good results.
One potential issue for headlamp bulbs replaced by LED is the beam pattern. The reflectors and heaglamp glass is designed to direct the beam from one area, the filament, which normally occupies a small area. LED,s use multiple light source points which do not focus the same. So some LED and HDI bulbs fitted into incandescent headlamp units will not function correctly from a beam pattern point of view They may be bright, but ghe beam pattern will be all over the place. Just something else to consider before you switch to LED.... Bit of a minefield at the moment.
Last edit: 03 Apr 2018 22:54 by Scimike.
The following user(s) said Thank You: Max Headroom
- Max Headroom
- Banned
- Thank you received: 217
04 Apr 2018 08:19 #191281
by Max Headroom
Replied by Max Headroom on topic Re:Front fog lamps.
:blush: Sorry 1066Boy - I think we've hijacked your thread :blush:
Apologies for that ! I have therefore looked in my handbook, found the list of bulbs on page 12-3 of my book, and lo and behold there is no mention of a front fog lamp!
My advice; remove a bulb and match it with one at Halfrauds
- Thank you received: 1853
04 Apr 2018 12:05 #191283
Replied by Lambert on topic Re:Front fog lamps.
Has there been a change in the law on these then, because I thought that retro fitting led to incandescent reflectors was a big no no? As in the whole light unit has to be specifically designed for led not just the actual light source?
04 Apr 2018 12:50 #191285
However whether you would actually be picked up on it is debatable
Replied by mlines on topic Re:RE: Re:Front fog lamps.
No, under construction and use everything has to be E marked and the marking only applies for the original tested item. So cheap Chinese import headlights or bulbs which, whilst the correct fitment, are significantly different from the original negate the E markingLambert wrote: Has there been a change in the law on these then, because I thought that retro fitting led to incandescent reflectors was a big no no? As in the whole light unit has to be specifically designed for led not just the actual light source?
- Max Headroom
- Banned
04 Apr 2018 14:53 - 04 Apr 2018 14:56 #191286
by Max Headroom
I asked a policeman friend of mine, and his thoughts were that it would be 'down to the individual officer', but he went on to say that so long as he can see you and you aren't dazzling him, then the likelihood was no, you'd get away with it! But that said, I have heard some people have failed an MOT on the grounds of LED lights being fitted which doesn't bode well, but again its probably down to the individual MOT tester.
BACK TO THE MAIN TOPIC.....:woohoo:
1066Boy, I just got back from Halfrauds, and those fog lights according to Halfrauds dreadfully slow computerised data book are H1
Replied by Max Headroom on topic Re:RE: Re:Front fog lamps.
mlines wrote: [
Last edit: 04 Apr 2018 14:56 by Max Headroom.
- 1066Boy
04 Apr 2018 16:46 #191289
by 1066Boy
Replied by 1066Boy on topic Re:RE: Re:Front fog lamps.
I think they are H1 bulbs but the Wikki page on here said H3 (unless I got it wrong) that was what confused me.
Time to create page: 0.149 seconds
