Front wheel drive
  • Dom
21 Mar 2018 13:31 #190677 by Dom
Front wheel drive was created by Dom
Quick question;
Is it ok to run a Jimny in front wheel drive (4x4 engaged but rear prop removed) while I'm waiting on parts/motivation to rebuild the rear diff?
I reckon the front end of the drive-train will be ok with it, but I'm not sure if the front hub vacuum mechanism will take prolonged use.
Do any of you have any thoughts or experience you could share on this?
Many thanks, Dom...
21 Mar 2018 18:12 #190687 by kirkynut
Replied by kirkynut on topic Front wheel drive
It won't do the car any harm if well maintained with greased CV joints but you are relying on your freewheeling hubs locking as they ought to all the time you plan to run it like this.
If they're working reliably then there is nothing to suggest they won't continue to do so.
The following user(s) said Thank You: Dom
22 Mar 2018 09:37 #190725 by Scimike
Replied by Scimike on topic Front wheel drive
As above your jimny will be fine with this. Seen similar done on Series landrovers when the rear half shaft snaps.. it's not going to give your locking hubs any issues so long as they work.
22 Mar 2018 10:51 #190728 by Busta
Replied by Busta on topic Front wheel drive
It will be fine. Don't worry about the hubs taking the load, they are mechanically very strong.
  • Dom
27 Mar 2018 15:50 #190917 by Dom
Replied by Dom on topic Front wheel drive
Thanks guys, I'll give it a go and see how it is.
The front hubs operate just fine but my concern was that they're designed to be left in the disengaged position, and prolonged use with them engaged may cause wear to the mechanism.
Hopefully I'll get it sorted before there are any issues...
  • Stumpjumper
27 Mar 2018 19:18 #190928 by Stumpjumper
Replied by Stumpjumper on topic Front wheel drive
I've been driving around all week with the rear prop removed & 4wd selected to shed light on some resonance I've been suffering.
Apart from a tendency to torque steer like an RS Focus, the experience wasn't much different than normal. However I'm glad the props back on...having not solved the resonance probs.
