Kingpin bearings / knuckle seals
- theoldseacaptain
- Junior Member
- Thank you received: 7
18 Feb 2018 09:44 #189422
by theoldseacaptain
Sadly jimny-less but still got the bug!
Replied by theoldseacaptain on topic Kingpin bearings / knuckle seals
Sorry - should have been more specific. It’s the nut on the ball joint that seems to be seized solid at the moment. Left it soaking after wire brushed the threads and some heat so fingers crossed..... I guess worst case will be cutting it off and hoping it unscrews out of the rod!
- Thank you received: 923
19 Feb 2018 15:05 - 19 Feb 2018 15:07 #189463
Replied by X8GGY on topic Kingpin bearings / knuckle seals
For the little nuts on the swivel ball seal you need some of these -
They have a reverse spiral cut inside the 'socket'...
www.machinemart.co.uk/p/5-piece-bolt-grip-set/
They'll grip the heads of rounded bolts
They also do this to fill the box with all sizes -
www.machinemart.co.uk/p/5-piece-bolt-grip-set-expansion-set/
Invaluable when working under a Jimny
Last edit: 19 Feb 2018 15:07 by X8GGY.
Time to create page: 0.182 seconds
