Immobiliser light stays on
- mattsccm
29 Jan 2018 21:12 #188963
by mattsccm
Replied by mattsccm on topic Immobiliser light stays on
Never even seen* it before suggesting that it goes out dead quick like the airbag light. Stays on now ,constant, engine spins well but won't fire. I had to get the book out to even find out that it was an immobiliser light. I wasn't aware it had an immobiliser until today.
* Lets say noticed
As nothing has changed apart from a battery being removed and replaced. It all points to that but I am so so sure that its on properly. Even added some jump leads from my Landy when it started to sound a bit sluggish with my frequent attempts to start it. Spins like buggery but not firing.
* Lets say noticed
- Jimx5
29 Jan 2018 22:05 #188964
by Jimx5
Replied by Jimx5 on topic Immobiliser light stays on
Have you checked the fuses which are next to the battery.
- CharlesS
29 Jan 2018 23:06 #188965
by CharlesS
Replied by CharlesS on topic Immobiliser light stays on
You need to determine what is missing as to why the engine will not start.
Have you verified the fuel pump runs when the ignition key is turned to ON? The fuel pump should run for a few seconds to pump up the fuel pressure. When you are cranking the engine; verify you either do or do not have spark to the plugs.
I have to agree with what was posted about he immobilizer light going off shortly after the engine starts; IF it's flashing then there is a problem with either the transmitter chip in the key or the immobilizer receiver module. Have you tried another key to see if there is a problem with the key you are using?
- mattsccm
30 Jan 2018 19:22 #188991
by mattsccm
Same with both keys. All fuses fine. Will check the fuel and spark but am bemused why they should fail when the battery is removed. And that light stay on!. Grrr
Sadly getting it to someone with a code reader is tricky as I can't drive it>
- mickt
30 Jan 2018 19:34 #188992
by mickt
Replied by mickt on topic Immobiliser light stays on
I would suggest you get the Battery load tested as just because it is turning the engine what seems normal there might not be enough power left to actually trigger the ignition. Especially as you mentioned you had to use jump leads as the battery soon went low!
- mattsccm
30 Jan 2018 21:53 #188999
by mattsccm
New one on order. However it did test out just fine. Bearing in mind its only 3 months short of 14 years old I am prepared to assume that its lying to me. Why this though? Its been flat, properly kipper like, before. Left door open for a couple of day ! Bumped, ran and fine. Reckon it hasn't like disconnecting.
What is the point though is not that its not firing but why the light staying on.
That implies an immobiliser issue linked to battery removal surely/
I hate modern cars. My Land Rover doesn't do this.
Time to create page: 0.199 seconds
