T-case Doubler: Vitara & Samurai in a '98 Jimny with 2" Body Lift. Will it fit ?
10 Jan 2018 03:08 #188208 by Rabid Rhino
I have an OTT Kicker 3. Not as good as a RockWatt unit with the breather hoses but I've had it for ages.
I'd like to put it in my 1998 Jimny that I just bought which already has a 2" body lift to hopefully clear the Vitara Bell-housing.
I spoke to RockWatt who said the doubler does go in & gave me a list of parts needed, however I'm looking for people here who have done it and ideally some build pics or even a thread link, as I'd like to see how it fits etc. I searched but didn't find any actually completed.
RW told me to take advantage of swapping out the Jimny transmission for the Vitara Gearbox & Bellhousing and also swap out the 1300 engine for a 1,600cc Baleno engine as the 4 bolts on the engine block match up perfectly with the 4 of the Vitara bellhouse. So no adapter or additional drilling required.
RW said I'll have to swap over the following parts from the 1,300 Jimny engine to the 1,600 Baleno motor.......
Injectors, Sump, Drive Belt Tensioner.
Any thing else needs swapping over ?
What starter motor would be needed ?
10 Dec 2019 19:06 #216369 by Rabid Rhino
Just bumping this cos its about to go in in the next few weeks so looking for advice.
Anyone got a RockWatt doubler to compare?
16 Dec 2019 08:40 #216504 by Busta
I've never seen anyone doing this before so any details and pictures you have would be greatly appreciated. RW will be the expert on this, so take his advice as golden.
11 Feb 2020 18:43 #218322 by Rabid Rhino
Still nothing ? I read on fb that Ray Edwards did it, said it was tight but no photos.
Also …...
Anyone put an Early Vitara Auto in their Jimny ? I gone one & it looks much bigger.
May need a 3" body lift. Anybody fitted one ?
12 Feb 2020 00:50 #218354 by zukebob
You are correct that the AW4 is compatible with the G series engine. All of the searching I have done in the past has focused on the possibility of an AW4 transmission behind an M series, but I never found anyone who put a Vitara transmission in any Jimny. If the person you mention did it, you may want to pm him to see if you can get some info.
Alternatively, you may want to do a search on the Auszookers forum. My memory (from when I was researching before) is that there was someone there who put the AW4 in an SJ. Although that isn't a prime comparison, it would likely help with ideas for fit issues.
Time to create page: 0.679 seconds
