Jimny auto engine roar - Sorted
- Wychall
27 Nov 2017 21:06 - 03 Dec 2017 15:33 #186805
by Wychall
Jimny auto engine roar - Sorted was created by Wychall
My daughter has asked me to look at a fault on her 2006 auto Jimny. On medium to hard acceleration the engine peaks at 3000 rpm and makes a load roaring noise. Lighter acceleration does not have the roar but does lack power as the revs rise. The engine itself revs freely throughout the range when in neutral. My initial thoughts were for a gearbox fault but the noise is not from the gearbox area.
Can anyone help to throw any light on this fault please?
Last edit: 03 Dec 2017 15:33 by Wychall.
- Thank you received: 2004
28 Nov 2017 04:52 #186806
Replied by Lambert on topic Jimny auto engine roar
I have yet to take delivery of my auto one but certainly on the test drive it did nothing like that. Starting with the simplest first, when was the gearbox oil and filter last changed?
- Wychall
28 Nov 2017 08:18 #186808
by Wychall
Replied by Wychall on topic Jimny auto engine roar
She's had the car three months and all has run fine. G/b oil looks clean although high. All road testing of the g/b has been good apart from this roar and 3k rpm lockout. As it is exactly 3k every time I assume it is an electronic problem, but is it g/b or engine?
Can anyone recommend a reasonably priced scan tool for the TCM?
- Wychall
30 Nov 2017 20:00 #186900
by Wychall
I've had a mechanic look at this now. Really impressed when his feedback started with "I know nowt about Suzuki's, but...".
His scan tool showed no stored codes and just one pending of O2 sensor bank 2 which he reset. The car now has a bit more power and revs better, but could the lambda problem cause low power and a roaring noise? Am I better off taking it to a Suzuki dealer?
01 Dec 2017 10:02 #186915
by facade
Replied by facade on topic Jimny auto engine roar
Check for blockage in the exhaust, or catalyst, and have a look at the air cleaner & inlet system for blockages too.
- Wychall
01 Dec 2017 18:10 - 01 Dec 2017 18:11 #186923
by Wychall
Thanks facade, you are thinking on the same lines as I am. My feelings are that it may be a blocked cat, which would explain the roaring noise involved. That will be my first check for tomorrow.
Has anyone managed to clear a cat, even temporarily, to confirm my suspicions? Perhaps a pressure washer?
Last edit: 01 Dec 2017 18:11 by Wychall. Reason: Spelling mistake
Time to create page: 0.091 seconds
