Snapped transfer box mounts
  • Iaitoo
31 Oct 2017 10:40 #185669 by Iaitoo
Snapped transfer box mounts was created by Iaitoo
Finally we got a bit of snow. Went out to try getting stuck in snow piles. Also wanted to try changing from 2h to 4h while moving. Since that can be practical on the roads here during winter. Well, I tried it while being stopped first. And the lever moved the entire transfer box :P Mounts gone! woho..
I'll just order the HD one from jimnybits. www.jimnybits.com/jimny/drivetrain/jimny...sfer-box-mounts.html
But want new bushings as well.
What do you recomend? The standard ones or the HD ones?
www.jimnybits.com/jimny/drivetrain/jimny...box-bushes-5454.html
www.jimnybits.com/jimny/drivetrain/jimny...sfer-box-bushes.html
31 Oct 2017 10:55 #185671 by mlines
Replied by mlines on topic Snapped transfer box mounts
I am not familiar with the specific Jimnybits ones. However I recommend you consider vibration. The firmer and more solid the bushes are the more noise is transmitted from the transfer box, through the chassis and into the cabin.
I have a polybush style mounting bush on my Transfer box and the vibration noise is considerable.
  • Daniel30
31 Oct 2017 14:19 #185677 by Daniel30
Replied by Daniel30 on topic Snapped transfer box mounts
I would get standard and keep a spare set in the boot, I had updated bushes and it drove me nuts
  • Iaitoo
31 Oct 2017 17:03 #185681 by Iaitoo
Replied by Iaitoo on topic Snapped transfer box mounts
Crap, went for the HD bushings. Read a few older threads about the jimnybits HD ones were about the same as the standard ones on noise. If they drive me nuts, whey aren't that expensive to replace at least.
Will I be able to replace the mouting brackets with the box on the car, or do I have to remove it?
31 Oct 2017 17:54 #185684 by Lambert
Replied by Lambert on topic Snapped transfer box mounts
I did mine with the box in place, bit of a faff but easy enough.
The following user(s) said Thank You: Iaitoo
  • Daniel30
31 Oct 2017 18:38 #185686 by Daniel30
Yeah can do it with the box on like 11/60 has said
