Belt Squeal
- Me and my Jimny
- Premium Member
- Thank you received: 9
29 Mar 2023 19:56 #248313
by Me and my Jimny
Replied by Me and my Jimny on topic Belt Squeal
Hey guys, another addition to this thread instead of starting another.My 01 plate has a similar story to this, squeal, snap then OK for a year then same again, and the last one lasted a few weeks. After reading here I checked the alternator and it did occasionally stick completely so ordered a new one. Just finished swapping it and I think I must have something wrong. It started squeeling on idle, then fine but squeeled revving, then fine revving but squeeled with lights on. Figured it was just bedding in, fine on a quick drive but squeeld when home and revving. Getting around 13.5 volts when running. I think it's tight enough but will try a bit tighter tomorrow. Any other advice?
29 Mar 2023 21:24 #248314
Replied by mlines on topic Re:Belt Squeal
Post number 4 at the top is my bet. Crankshaft pulley. Shine a torch on it and look for a wobble
Sent from my moto g42 using Tapatalk
- Me and my Jimny
- Premium Member
29 Mar 2023 21:40 #248315
by Me and my Jimny
Replied by Me and my Jimny on topic Re:Belt Squeal
Thanks Martin
I did look at that as I saw it earlier in the thread, I couldn't see any movement on there at all, but I didn't use a torch. Did you suggest the torch because its dark now, or is it actually easier to see movement with a torch ?
29 Mar 2023 22:05 #248316
Easier to see the movement
- Me and my Jimny
- Premium Member
30 Mar 2023 07:51 #248318
by Me and my Jimny
OK thanks for the tip, I'll try that later and if not obvious I'll apply more tension.
Also conscious it could just be a build up of crap on that pulley from all the burnt belts, someone also mentioned in the thread. I did my best to clean it but it's bloody awkward to get to
- Me and my Jimny
- Premium Member
30 Mar 2023 17:36 #248326
by Me and my Jimny
Couldn't see any movement with the torch Martin, so think that's OK
More tension seems to have worked, no squeel and a constant 14.10 volts, so I think so far so good
Time to create page: 0.886 seconds
