Spark plug socket
30 Sep 2017 07:35 #184669 by HUN
Spark plug socket was created by HUN
Hi Gents,
I'd like to check/ replace the spark plugs in my VVT Jimny. My old socket does not fit into the hole but it's the right size for the spark plug because it fits on the spark plug when its in my hand... Looks like I need a socket with thin wall thickness?
Can someone attach a link of an appropriate/tested socket, please? I'd like to avoid purchasing another useless piece. Thank you.
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
30 Sep 2017 08:57 #184672 by Lambert
Replied by Lambert on topic Spark plug socket
I have this bahco set and it fits perfectly. [url/] www.screwfix.com/p/bahco-33pc-1-4-3-8-so...PEzNYCFdMC0wodUMkCPA [/url]
  • shakennstirred
30 Sep 2017 14:34 #184679 by shakennstirred
Replied by shakennstirred on topic Spark plug socket
No eBay APP ID and/or Cert ID defined in Kunena configurationI got this
30 Sep 2017 18:42 #184685 by HUN
Replied by HUN on topic Spark plug socket
Thanks guys, I think I gonna try the one from ebay first. If it does the job then happy days!
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
The following user(s) said Thank You: shakennstirred
01 Oct 2017 20:29 - 01 Oct 2017 20:29 #184715 by kirkynut
Replied by kirkynut on topic Spark plug socket
Make sure it has the rubber grip for the plug or you'll never get it out the hole without a magnet on a stick and threading the new one in will be a nightmare. Been there, done that on other cars in my youf!
Last edit: 01 Oct 2017 20:29 by kirkynut.
02 Oct 2017 13:02 #184742 by Busta
Replied by Busta on topic Spark plug socket
kirkynut wrote: Make sure it has the rubber grip for the plug or you'll never get it out the hole without a magnet on a stick and threading the new one in will be a nightmare. Been there, done that on other cars in my youf!
You can normally get the coil pack back on and pull it out with that :)
Time to create page: 0.105 seconds
