No 4th gear in my auto
17 Sep 2017 20:27 #184208
Replied by mlines on topic Re:RE: No 4th gear in my auto
When you say you put new fluid in, did you pump the old fluid out? The "drain" doesn't drain so something like 2 thirds of the old fluid is still in there.
- Robandkath
17 Sep 2017 20:34 #184209
by Robandkath
Replied by Robandkath on topic Re:RE: No 4th gear in my auto
Completely drained oil cooler hoses off and pan off filter so not a drop in it
- Robandkath
17 Sep 2017 20:41 #184210
by Robandkath
Cheers if it's electrical I'll have take it somewhere as I have no idea although I do have a volt meter unless someone on here from southeast Queensland fancys having a look
02 Jan 2018 00:53 - 07 Jan 2024 18:44 #187956
by h_hezzah
Replied by h_hezzah on topic Re:RE: No 4th gear in my auto
Check the transmission temp sensor, since the Jimny does not change into 4th until the sensor reads above about 30 degrees Celsius. So may be your sensor is sending wrong reading to the TCM. It also does not go into 4th if Coolant temp is below 50.
Last edit: 07 Jan 2024 18:44 by h_hezzah.
- Thank you received: 227
03 Jan 2018 01:00 #187984
by zukebob
Replied by zukebob on topic Re:RE: No 4th gear in my auto
Forgive me if I state something that might be overly obvious (simple) but that's the place I like to start.
The auto transmission on the Jimny has 2 positions for drive. When the shift lever is to the left, it will shift from 1st to 4th. If you move the shift lever slightly to the right, it will only shift from 1st to 3rd.
Anticipating that this isn't the problem, I would lean toward the comments by Kirkynut and OllieNZ
- CharlesS
07 Jan 2018 19:56 #188107
by CharlesS
Replied by CharlesS on topic Re:RE: No 4th gear in my auto
In the states when the transmission is serviced the fluid is pumped thru the transmission; since draining the cooler, hoses and pan will not drain the fluid in the torque converter. The only way to replace the fluid remaining in the torque converter would be to pump the fluid thru the transmission OR drain the cooler, hoses and pan, refill and cycle the transmission then drain and refill the pan again. The drain and fill does not guarantee a complete fluid replacement.
Time to create page: 0.835 seconds
