Headlight adjustment
- 2013gary
16 Jun 2017 09:15 #182092
by 2013gary
Headlight adjustment was created by 2013gary
Hi,
My Jimny failed it's MOT last week because both of the headlight aims were too low. The tester said he tried to adjust them but was unable to as the adjusters didn't work.
So I took it home, parked next to a wall and fiddled around with the two adjuster bolts on the back of each healight until I thought I had solved it.
Took the car back for a retest today and the headlight aims are still too low.
Do the adjuster mechanisms ever fail, and is there a way to fix them? Replacing the headlights seems a bit drastic.
16 Jun 2017 19:14 - 16 Jun 2017 19:16 #182116
Replied by Daniel30 on topic Headlight adjustment
What reg is it ? Mine has a headlight adjustment on the right of the steering wheel
Last edit: 16 Jun 2017 19:16 by Daniel30.
- Thank you received: 2004
17 Jun 2017 05:45 #182125
Replied by Lambert on topic Headlight adjustment
Also check the bulbs are seated correctly in the reflectors, they should only go in one way but that doesn't mean they haven't been forced in wrong.
- 2013gary
17 Jun 2017 06:41 #182129
by 2013gary
Replied by 2013gary on topic Headlight adjustment
Thanks for the helpful replies. I have owned this Jimny for 3 years and have never noticed the adjuster on the right of the steering wheel!
So what are the two adjuster bolts on the back of each headlight for?
I will also check the bulbs are seated correctly just to be sure (although they should be because I put them in)
17 Jun 2017 06:46 #182131
by Keithy
Replied by Keithy on topic Headlight adjustment
If the bulb was in wrong the pattern would be wrong......so did the adjuster in the car work?
The one on the headlight is a limiter I believe
- 2013gary
18 Jun 2017 04:35 #182149
by 2013gary
The adjuster in the car seemed to work - the beam moves up and down. I won't know for sure until they test it again with the alignment device. As the MOT bloke tried to adjust the headlights during the test I'd have thought that he would have looked inside for a switch.
There are two bolts on the headlight itself. One at the top and one at the bottom. The ones on top didn't appear to do anything at all
Time to create page: 0.107 seconds
