front bump stop
17 Feb 2017 13:47 #178121
by safari
if u worry u die if u dont worry u still die so why worry
front bump stop was created by safari
i need some help regarding front bump stop. i have 3" lift have custer correction arms and tried to extend the bump stop front cause rear is ok .
my problem is the bump stop is not touching so is not stopping .When pressed without spring it is closing on the shock ,it is no where near to stop on the diff it is aiming to the front ,has anyone had my same problem or any ideas tks.
- TomDK
17 Feb 2017 13:55 #178122
by TomDK
Replied by TomDK on topic front bump stop
If you have a 3" suspension lift you also need to extend your bump stops. Both front and rear.
Bits4vits.com sells bump stop extenders.
www.bits4vits.co.uk/store/jimny/bump-sto...4vits/prod_1270.html
17 Feb 2017 15:27 #178129
by safari
Replied by safari on topic front bump stop
tks for the reply
i have extened the bump stop the rear with extention works fine the problem r the front they dont bump on the diff pass near the diff because the diff is a bit rotated because of the lift even though i made the custer correction
- TomDK
17 Feb 2017 15:58 #178130
by TomDK
Sounds odd. Could you take a pic.
19 Feb 2017 08:51 - 19 Feb 2017 08:52 #178184
by safari
Last edit: 19 Feb 2017 08:52 by safari.
- TomDK
19 Feb 2017 08:55 #178185
by TomDK
Okay, see what you mean. There's also the possibility of installing the bump stop on the underside of the chassis so it hits the axle housing next to the spring. This will of course require some welding.
Time to create page: 0.108 seconds
