banging in first and second on pulling away
  • mg mel
9 years 10 months ago #176569 by mg mel
Hi all I am new to this forum .I personally am an MGB owner .This is a question on behalf of my ex wife who has an 06 jimny not used off road but gets regular use .the other day she heard a loud bang when pulling away in 1st and second she took the car to her local garage .They said it was a problem with the gearbox .The mechanic took out the drain plug an told her there were bit of metal on the magnet in the plug . I drove the car today and there seems to be no other noises from the box the other three gears seem ok .Surely there would be a terrible noise from the box if it were the gears broken .I looked at the rear gearbox or rear engine mount, as suggested in a reply on here but could find no problem. Has anyone any other ideas before we go and get the box sorted
  • jim
9 years 10 months ago #176578 by jim
Hi Mel, the vvt engine models like your ex wife's are known for destroying bearings. I had mine refurbished recently and I saw the failed bearing. There's a company that does a drop in bearing kit and I got my mechanic to fit the new parts and clutch and saved a fortune.
However, my gearbox didn't bang, my box and others I have heard of start to whine usually in 3rd or 4th. I would get her to change the oil in the gearbox because of the metal shavings, I do mine when I do regular engine oil changes because its very easy and you can do it without having to jack the vehicle up.
The jimny shouldn't be driven in 4x4 on a grippy surface as you can get transmission wind up. Check if the 4x4 is engaging properly. if there is wind up you can spin the wheels in reverse on gravel to unwind it. I doubt this is the issue but again worth checking as in did read similar symptoms before.
As you mentioned check the gearbox aka as rear engine mount. They are prone to delaminating but may not often show until properly removedn.
Available here : www.bigjimny.com/store/rear-engine-mount-gearbox-mount.html
I have found with a couple of jimnys I have used when banging the clutch up too quickly along with hard acceleration they do make some clunky noises.
It could also be Under acceleration the engine moves and an exhaust can bang around, I had this issue with the rear silencer hitting the tow bar.
As you hadn't experienced it whilst driving, I doubt its anything serious. I
  • mg mel
9 years 10 months ago #176586 by mg mel
Replied by mg mel on topic banging in first and second on pulling away
Hi thanks for that I will get it looked at
  • mg mel
9 years 10 months ago #176588 by mg mel
thee clutch by the way is a new one two/three months ago . Mel
  • 1066Boy
9 years 10 months ago #176592 by 1066Boy
Replied by 1066Boy on topic banging in first and second on pulling away
Transfer box chain slipping under the extra torque of a low gear?
  • mg mel
9 years 10 months ago #176611 by mg mel
thanks for that .The ex tells me she had to move the car tonight but when she did there was no noise she only drove it 250 yards or so she then reversed up because she thought it had cured itself .drove the same distance no noise reversed back and the noise occurred again very odd .
Time to create page: 0.104 seconds
Powered by Kunena Forum
