Front washer jet motors not working
- jim
05 Jan 2017 19:53 #176277
by jim
Front washer jet motors not working was created by jim
No eBay APP ID and/or Cert ID defined in Kunena configurationI've never had a washer motor fail on any of my cars before and its typical they break when there's loads of road salt spray.
I thought my washer jets had iced up but I had in fact run out of windscreen wash. Now both my front washer bottle motors aren't working and don't even make the whirring noise. I checked the fuse for the jets but that was fine and the rear windscreen jet is fully functioning.
I fear I may have destroyed them when running them dry for a few seconds. But strange both went.
Currently I can only find cheap ebay ones.
- 1066Boy
05 Jan 2017 20:19 #176278
by 1066Boy
Replied by 1066Boy on topic Front washer jet motors not working
I have used the cheap ones on a car and they were fine. I run 2 in tandem so one fed each jet.
Now that shifts the mud!
- jim
05 Jan 2017 20:34 #176281
by jim
Replied by jim on topic Front washer jet motors not working
It would be great to modify it to use heated water.
- jim
06 Jan 2017 19:46 #176328
by jim
I see what you mean about running one per jet. I managed to fix it today swapping them over to use the rear for my front may have cleaned the terminals on the plug. I also took off the jets and tubes and cleared them out. They are working perfectly now.
1066Boy wrote: I have used the cheap ones on a car and they were fine. I run 2 in tandem so one fed each jet.
- mickt
07 Jan 2017 10:19 #176337
by mickt
Replied by mickt on topic Front washer jet motors not working
So was the motor kaput then?
- jim
07 Jan 2017 10:51 #176340
by jim
Hi Mickt,
No the motor is now working fine I think putting the plugs on and off must have cleaned the terminals better than I did with a wire brush.
mickt wrote: So was the motor kaput then?
Hi Mickt,
Time to create page: 0.170 seconds
