Manual hubs - blinking 4WD light fix (tested)
- wilku
23 Nov 2016 21:28 #174851
by wilku
Manual hubs - blinking 4WD light fix (tested) was created by wilku
I've just finished one simple modification to my Jimny.
As I have already replaced automatic hubs with manual ones, removed the vacuum pipes and solenoids all that was left was fixing the blinking light on the dashboard. I took some photos and I've put a page on the wiki describing the process. It's my first contribution to the wiki so any constructive feedback is highly appreciated. Enjoy responsibly.
- jewi
23 Nov 2016 22:21 #174854
by jewi
Replied by jewi on topic Manual hubs - blinking 4WD light fix (tested)
thanks for the info
25 Nov 2016 17:01 #174918
www.bigjimny.com/index.php/forum/7-jimny...-light-with-pictures
Replied by helijohn on topic Manual hubs - blinking 4WD light fix (tested)
Is it like this that I did?wilku wrote: I've just finished one simple modification to my Jimny.
- wilku
26 Nov 2016 18:02 - 26 Nov 2016 18:05 #174948
by wilku
Replied by wilku on topic Manual hubs - blinking 4WD light fix (tested)
Not exactly. I can't identify the plug that you disconnected and "bridged" (or whatever the word in English for that be), so I can't tell if the result is the same, and I actually doubt it.
I think your solution might be tricking the 4wd module into lighting up the 4wd indicator, while mine just makes a direct connection from the switch in the transfer box to the bulb of the indicator and allow to remove the 4wd module completely.
//EDIT: and I have a question - is your solution for the electronically steered transfer box? (button-operated) because mine is for a manual one (lever)
Last edit: 26 Nov 2016 18:05 by wilku.
Time to create page: 0.338 seconds
