Newbie quezzie
  • Keefe
18 Nov 2010 19:47 #6116 by Keefe
Newbie quezzie was created by Keefe
Hi All,
Got a 01 Jimny and just had all the rear floor welded up, it was well rotten.
It has a 2" Rhino Ray spring lift with all the other tackle. Shocks, castor correction, etc etc.
I have just obtained a 2" body lift, complete except for the two front bolts.
Can anyone tell me the size, length, thread and type of bolts I need please?
Are they high tensile bolts? M10 or M12 x 1.25? Shank length, length of thread etc.
Looking forward to getting to know you all.
Keith:)
  • Reloaded
19 Nov 2010 09:48 #6133 by Reloaded
Replied by Reloaded on topic Re: Newbie quezzie
Hi Keith
I've got absolutley no answer to your question I'm afraid, but welcome to the forum anyway! :)
I'm sure someone will be along that's got a clue sometime.
Cheers!
Mick
19 Nov 2010 10:16 #6134 by mlines
Replied by mlines on topic Re: Newbie quezzie
I have a body lift kit still in the shop from an experiment to get them made up. If you can identify which bolts are the front ones I will tell you the size.
The following user(s) said Thank You: Keefe
  • Keefe
19 Nov 2010 10:31 #6135 by Keefe
Replied by Keefe on topic Re: Newbie quezzie
Hi both of you and thanks for the welcome.
Hope you don't mind but I've used your pictue, Martin.
I've circled the two bolts, and washers that I need.
They're the ones that go at the front.
I have a BAP bolts copmpany near me, so perhaps I might be able to get them there or have them made up, once I have the correct sizes?
By the way, great site, spent the last couple of days snooping around. Brilliant.
Hope I can be of some help too in the future.
  • adamjimny
22 Nov 2010 16:11 #6302 by adamjimny
Replied by adamjimny on topic Re: Newbie quezzie
sorry only just seen this topic. sizes are as follows.
155mm long (including the bolt head 149mm without)
M10 bolt size
only 35mm of the bolt is threaded at the end
and i have high tensile ie rated 8.8 on bolt head
any more info needed?
22 Nov 2010 16:39 #6308 by mlines
ADamjimny, there is one more bit of info - 1.25mm Metric Fine
So thats 155mm x M10 x 1.25 Metric Fine
Time to create page: 0.214 seconds
