Remote Key - Won't Unlock but Lock Works
  • neilbaldwin
10 Oct 2016 20:58 #173340 by neilbaldwin
Remote Key - Won't Unlock but Lock Works was created by neilbaldwin
Hello all,
Had a weird thing start happening with my 06 plate. The remote key will no longer unlock the car though locking it works fine.
I've replaced the battery and also checked continuity on the buttons themselves (which appear to be OK).
Any ideas?
Cheers,
Neil
  • jim
10 Oct 2016 21:09 #173342 by jim
Mine was harder to use it worked better after cleaning it out but also the rubber buttons wear down and dont make good enough contact.
  • neilbaldwin
11 Oct 2016 05:38 #173346 by neilbaldwin
Replied by neilbaldwin on topic Remote Key - Won't Unlock but Lock Works
Cheers Jim
It's definitely not the rubber buttons as I took the circuit board out of the key, taped the battery to it and then tried pressing the micro switches on the PCB itself. Same thing: lock works, unlock doesn't. Really odd.
11 Oct 2016 06:51 #173349 by jackonlyjack
  • Daniel30
11 Oct 2016 15:59 #173370 by Daniel30
Replied by Daniel30 on topic Remote Key - Won't Unlock but Lock Works
Maybe it's the central locking thing that triggers the lock might be faulty as in locks the doors but dosent unlock it?
11 Oct 2016 20:45 #173399 by Rhinoman
If you manually lock and unlock using the button on the door does it feel stiff?
Time to create page: 0.210 seconds
