Key snapped!
- barty9
06 Oct 2016 11:17 - 06 Oct 2016 11:24 #173202
by barty9
Key snapped! was created by barty9
I have just bought an old 2000 model Jimny and the key has just snapped in the door lock.
it is just the tip but the car won't start. I have a spare key but would welcome any thoughts and opinions in getting the tip out of the lock and getting a new key cut.
Thanks in advance
Thanks in advance
Last edit: 06 Oct 2016 11:24 by barty9.
- Thank you received: 2004
06 Oct 2016 11:48 #173205
Replied by Lambert on topic Key snapped!
The only thing that I could suggest would be a massively strong magnet and the other part of the key and as much patience as you can muster.
- jim
06 Oct 2016 13:21 - 06 Oct 2016 13:24 #173207
by jim
Replied by jim on topic Key snapped!
Hi Barty, someone snapped a key in some metal shutters at work, so before calling a locksmith I had a go myself and got it out.
I used two pieces of thin wire which has to be fairly stiff to go above and below the broken key.
For the piece of wire that goes above the broken key I used some needle nose pliers to put a very small bend at the end to hook it out .
The bottom piece of wire is used to depress the mechanism inside.
Last edit: 06 Oct 2016 13:24 by jim.
- barty9
06 Oct 2016 14:55 #173210
by barty9
Replied by barty9 on topic Key snapped!
Timsons have cut me a new key from the spare @ £40. I will give the wire trick a go. Thank you
07 Oct 2016 17:05 #173227
by facade
Didn't you mean the snapped off key won't turn in the ignition rather than the car won't start?
If you get a plain metal key cut to the spare for about £5, and attach it to the keyring right next to the broken key the transponder chip in the old key will be read by the car when you turn the plain key in the ignition lock, and the car will start and run fine.
If you take the lock off the door and remove the nut & lever from the back, insert what is left of the key the barrel will push out, then you can winkle the broken bit out with some stiff wire.
Replied by facade on topic Key snapped!
barty9 wrote: I have just bought an old 2000 model Jimny and the key has just snapped in the door lock.
Thanks in advance
07 Oct 2016 18:12 #173233
Replied by helijohn on topic Key snapped!
It is possible to open the lock barrel itself once off the door. You can then easily access the internals to get the key tip out. I had to work on mine when it got mauled by some scrote. Need to watch out for the little springs and take care with the bezel tab so as not to snap them off so it's OK to refit.facade wrote:
Time to create page: 0.103 seconds
