Gearbox mounts
- leftcase
24 Jul 2016 12:45 #170437
by leftcase
Gearbox mounts was created by leftcase
After completing the following changes to try and get rid of the dreaded death wobble, I'm still having some issues:
Track rod ends replaced
King Pins replaced
King Pin bearings replaced
The vibration seems to come directly through the gearstick, and doesn't occur all of the time (it did originally but the kingpins seemed to fix it). For instance, I can be driving along at 45 and be shaken all over, but somewhere else I can be doing the same speed and the ride is smooth.
A friend suggested that the rear engine / gearbox mounts seemed a bit soft, but I can't figure out what I need to buy to replace these. Does anyone know?
Thank you
King Pins replaced
Thank you
24 Jul 2016 15:04 #170443
Replied by Daniel30 on topic Gearbox mounts
are you transfer box mounts all ok ??
- leftcase
24 Jul 2016 15:08 #170444
by leftcase
Replied by leftcase on topic Gearbox mounts
I suspect that is what he was on about. There are 3 of them aren't they?
24 Jul 2016 15:14 #170445
by Busta
Replied by Busta on topic Gearbox mounts
There is one gearbox/rear engine mount that often de-laminates. Typically this causes an occasional grinding noise under hard acceleration in the lower gears. When mine failed I didn't notice any un-usual wobble. The gearstick shaking is quite normal for a vehicle built like the Jimny where it is mounted directly to the gearbox. To check the gearbox mount, lay under the car and see if you can lift the end of the gearbox. It will be quite apparent if the mount has separated.
Death wobble refers to a severe steering wobble, for which the engine and gearbox would not be the cause.
If you still have steering wheel wobble (death wobble) then persevere with the solutions offered in Kirkynut's sticky thread on the subject.
The following user(s) said Thank You: leftcase
24 Jul 2016 15:14 #170446
yeah thats right
Martin bigjimny shop will be able to get you some but there is a gearbox mount aswell that can break
- leftcase
24 Jul 2016 15:22 - 24 Jul 2016 15:26 #170449
by leftcase
Couldn't find it in the shop here, but looks like Martin has an eBay shop too selling them. I think this is it:
ebay.eu/2a9OuP9
I've been through the death wobble list here: www.bigjimny.com/mediawiki/index.php/Death_Wobble
2 King Pin Bearings
Replaced
3 Track Rod Ends / Steering Rod Ends
Replaced
4 Panhard Rod Bushes
Seem OK
5 Front Wheel Bearings
No wheel movement
6 Radius Arm / Trailing Arm Bushes
Seem OK
7 Cleanliness
Had wheels off and cleaned up
8 Swivel Seal
Replaced
9 Tyre Pressures
Checked
10 Wheel Balancing
Not done (needs new tyres)
11 Disk Brakes
Replaced front disks and pads
2 King Pin Bearings
Replaced
Replaced
Seem OK
No wheel movement
Seem OK
7 Cleanliness
8 Swivel Seal
Replaced
9 Tyre Pressures
Checked
10 Wheel Balancing
11 Disk Brakes
Last edit: 24 Jul 2016 15:26 by leftcase. Reason: error 500
Time to create page: 0.109 seconds
