Heater matrix
12 Jul 2016 15:03 #169920
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Heater matrix was created by Mike G
Ok,
Just a query. Can anyone tell me how hard it is to get to the heater matrix in the jimmy? Also, can you visually inspect it whilst it's in situ/operation, or would it need to be removed to have a good inspection? Once it's located, how hard is it to remove it?
I'm only asking as I am investigating a loss of coolant and want to be clued up before I start. I'm currently awaiting a pressure test kit and combustion gas tester. Can't see any visual leaks anywhere and the radiator cap looks to be clean (will need to test it as well).
Every time I drive my jimmy about 60 miles, I need to top up the header and fill the radiator about 2-3 teacups full (using a kettle to fill it up, so taking the measurements from there :laugh: )
Many thanks guys.
Many thanks guys.
12 Jul 2016 16:22 #169923
Replied by Daniel30 on topic Heater matrix
ask/PM this chap he has just removed his and now has another problem but he might be able to answer your question
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=60580
12 Jul 2016 18:09 #169930
by Mike G
Replied by Mike G on topic Heater matrix
Thanks Dan,
I'll give him a shout. Hopefully I won't have to venture to those depths, but forewarned is forearmed and all that. I think after pulling out the dash I will be all forearmed, like popeye. :laugh:
- Thank you received: 706
12 Jul 2016 18:14 #169931
Replied by jackonlyjack on topic Heater matrix
if it's leaking from matrix your carpet should be wet
Jack
Jack
12 Jul 2016 22:43 #169962
by Mike G
Well, I haven't noticed any wetness on the carpet, but my windows did steam up a little easily, but that could be normal for the jimny.
I'm hoping it's a perished rubber hose or bad hose fitting. Will have to wait for the testing kit to arrive before I get enough evidence to proceed with a proper investigation. Until then, I think I'm just going to have to stop using the motor for a bit. I'll update as soon as I get some info.
- mickt
13 Jul 2016 19:26 #170001
by mickt
Replied by mickt on topic Heater matrix
The dark side is a head gasket going. Do a compression check or get a sniffer test done to confirm would be my advice before blaming the heater matrix.
Time to create page: 0.096 seconds
