Transmission Temp OBD2 PID
- Thank you received: 227
10 years 5 months ago #167100
by zukebob
Transmission Temp OBD2 PID was created by zukebob
I recently ordered a OBD2 reader from Amazon. I will be purchasing Torque Pro to use with it. With international shipping, the reader should be here in 18 to 32 days. I thought that should give me plenty of time to get the information I need to add a custom PID and create a transmission temp gauge on the dashboard. I haven't been able to find anything on a Jimny specific PID for the transmission temp. Has anyone here already sorted this out?
Thanks
Bob.
Thanks
Bob.
10 years 5 months ago #167122
by facade
Replied by facade on topic Transmission Temp OBD2 PID
The transmission controller sends oil temperature to the engine ecu along the CANBUS, presumably so the engine can idle faster when it is cold and possibly reduce max power when it is over-temperature, but I would only expect a P code if the sensor was reading out of limits, as the actual temperature isn't a fault.
You might find that torque can give you a gauge of the oil temperature via the eobd2 socket, or it might need a Suzuki specific scantool.
Rhinoman might know, but most of us have manual transmission so we've never seen any oil temperature data on our tools.
10 years 5 months ago - 10 years 5 months ago #167197
by Rhinoman
Replied by Rhinoman on topic Transmission Temp OBD2 PID
What year is it? its probably not CANBus, the problem will be if the transmission diagnostics is connected to a different pin on the socket. The FSM will list the codes available, Suzuki tend to only implement legislated codes on the EOBD interface, other data uses a non-EOBD protocol.
Last edit: 10 years 5 months ago by Rhinoman.
10 years 5 months ago #167203
by zukebob
Replied by zukebob on topic Transmission Temp OBD2 PID
Rhinoman - It's a 2015 sold in the Philippines. Up to this point, I haven't suspected that the protocols used would be different in different market areas, except as required for VVT. That wouldn't seem to make much sense but don't know for sure. Thought that I should mention location just in case since the M13 engine here is non-VVT.
If Suzuki only implements the legislated codes, I don't think transmission temp is one of them. That would probably bring me back to the point facade made. It's quite possible that I would only be able to read the TCM with a Suzuki scantool. I may have made too many assumptions based on my previous experience.
Any feedback is appreciated
Bob
Bob
10 years 5 months ago #167235
by Rhinoman
Suzuki use the same protocols worldwide which are their SDL protocols, traditionally they have only added OBD2 or EOBD for markets that require it but most of the world is now moving to EOBD so they are starting to include both interfaces as standard. They may well use EOBD in the Philipines if the ECU is also used elsewhere. The early VVT model ECUs used KWP2000, later Euro models use CANBus, if you have a separate TCM then that may use a different protocol to the Engine ECU. Your OBD2 reader should tell you which protocol the engine ECU uses.
The following user(s) said Thank You: zukebob
- gusthegorilla
10 years 5 months ago #167244
by gusthegorilla
Replied by gusthegorilla on topic Transmission Temp OBD2 PID
Sorry for butting in, Rhinoman, but how the he'll do you get to know all this stuff???
I find it quite bewildering :blink: :blink:
Time to create page: 0.089 seconds
