Fear of front locker
28 Apr 2016 21:10 #165950 by Keithy
Replied by Keithy on topic Fear of front locker
Richie rich here.....I have a pair of ARB lockers.
If I break something using the ARB lockers I'll be sure to let the OP know how it happened.....I only use 2 karat diamonds as studs in my tyres these days...cutbacks!
  • Sandro
29 Apr 2016 05:55 #165962 by Sandro
Replied by Sandro on topic Fear of front locker
Just found on used market a set of stock CV+joints from a scraped Jimny for only 120€ ... i have now them as spare, so i can try go a little bit harder with no fear of empty (again) the wallet ... seems to be a good compromise between being rich and being under bankruptcy :P
  • TomDK
29 Apr 2016 12:45 #165980 by TomDK
Replied by TomDK on topic Fear of front locker
Sandro wrote: Just found on used market a set of stock CV+joints from a scraped Jimny for only 120€ ... i have now them as spare, so i can try go a little bit harder with no fear of empty (again) the wallet ... seems to be a good compromise between being rich and being under bankruptcy :P
Just remember that you don't have to buy a lot of used CV's and axles before it's cheaper to udgrade to uprated shafts and CVs instead :)
  • Sandro
29 Apr 2016 14:41 #165991 by Sandro
Ok ... but HD shafts needs usually 26 spline diffs ... and my ARB is 22 spline ...
HD kit + 26spline ARB side gears = how many couples of stock CV+shaft ?
Frankly speaking I think i will ever snap an axle only 1 time ... them i will know which is the kind of force required to break a shaft/cv ... and i will stay away from that ...
I read several discussione about HD shafts/CV and they break too ... just need more abuse ...
I do not want to trash my car, but only to know how much i can push before some thing will give up ... i will learn this by myself eventually ... but if anyone will give me già 1st person experience, i'll be happy and will think twice when i will found a tricky spot where i' ll need 2 lockers on ...
  • TomDK
29 Apr 2016 14:57 #165992 by TomDK
Sandro wrote: Ok ... but HD shafts needs usually 26 spline diffs ... and my ARB is 22 spline ...
  • TomDK
29 Apr 2016 15:01 #165993 by TomDK
Sandro wrote: Hi everybody,
i have just bought a 2nd hand jimny, from a friend who downgraded to a Land Rover ...
It's a 2006 vvt, with 2" lift, 215/75 mud and front/rear Arb lockers ...
the old owner scared me telling that he snapped 2 CV joints using the front lockers, and suggested me to be very gentle with it ...
So, as i do not want to break anything, i use the front lockers only at very light gas, and no steering ... there have been times when i could not pass an obstacle with rear lockers only (+ full power) ... but even woth light foot (let say 3000rpm) and 2 lockers i didn't made it ...
I spend already almost more than i could to buy the car, so it's not time to invest in HD axles now ... nor to break the stock ones ...
I would just ask you to collect here a "front locker damages" database, indicating how you snapped yr cv or shafts, just to understand how much i can reasonably push before asking too much to the front axle
Thanks in advance
The whole point of HD shafts and CVS is that they can take more abuse before breaking. So what's your point?
I run 22 splines HD shafts and CVS. They're with 5 year warranty. But not cheap and can take a good deal of abuse compared to standard. I also run with front air locker.
Time to create page: 0.182 seconds
