headlight problems
  • Marki
10 Mar 2016 15:45 #163575 by Marki
headlight problems was created by Marki
I've done a quick search and not found anything obviously related .
I'd noticed that the left hand headlight looked like it had blown so changed the bulb but it hasn't got any brighter. I've also just noticed that the dash warning for high beam isn't working.
I've done a quick check with a multimeter and it shows 8 volts going to the left bulb and 14 volts to the right. If I take out the fuse for the right light then they both go out, if I remove the left hand fuse then they both stay on but the left hand is still dim. Voltage at the fuse box match the voltage at the bulb. I'm about to check the relay but does anyone have any thoughts on what else may need checking? Anyone else experienced this?
  • Marki
10 Mar 2016 15:57 #163576 by Marki
Replied by Marki on topic headlight problems
Soooooo. No relay. Guess I'll have to check the switch next. Suppose it makes sense to sort out the High beam marker just in case it's something weird like that causing the problem.
  • mickt
10 Mar 2016 16:12 #163577 by mickt
Replied by mickt on topic headlight problems
Check your earth points for bad connections.
  • Marki
10 Mar 2016 16:22 #163578 by Marki
It earths through the column switch. Never simple!
  • Marki
10 Mar 2016 18:06 #163579 by Marki
So I've diagnosed it as no power feed to the left hand lamp, this is also the reason for the lack of warning light surprisingly. Connect blue/white direct to battery and all is well. Looks like a break in the wire somewhere. Must be far easier to fit a new power feed rather than trying to track the fault. I'd prefer to do it right but the wire seems to get lost in the main loom. after leaving the light.
  • Basketcase
10 Mar 2016 22:02 #163602 by Basketcase
Replied by Basketcase on topic headlight problems
Sounds stupid but have you changed the fuse? I've had a partially blown fuse be funny before, it looked perfect but a new fuse fixed the problem? Worth a go if you haven't already
Time to create page: 0.099 seconds
