Passenger airbag
- Roger Fairclough
- Thank you received: 225
10 Jul 2024 11:17 #256719
by Roger Fairclough
Replied by Roger Fairclough on topic Passenger airbag
My air bag warning light on the dash is still coming on when it feels like it so is there a way to either remove the bulb or somehow switch it out?
2020 Gen.4
Cheers
Roger
2020 Gen.4
Cheers
Roger
The topic has been locked.
10 Jul 2024 12:09 #256722
by Motacilla
Replied by Motacilla on topic Passenger airbag
No, and no.
Why would you want to bodge a new car? Use a scan tool to find the problem, and fix it. If you can't, then take it to a professional.
No offense intended, Roger, but disconnecting the warning light is simply shooting the messenger.
- Roger Fairclough
10 Jul 2024 20:15 #256727
by Roger Fairclough
It's called desperation and being pissed off. I don't trust the main dealer ever since they got uppity when I said I would be doing the servicing from now on. I must try and find a decent auto-electrician in Redditch or district who knows the Jimnys systems. Not an easy job.
Roger
ps No offence taken, your comment was justified.
Roger
11 Jul 2024 13:07 #256737
by Motacilla
I sympathise, Roger, I really do.
Good help is hard to find. There might not be enough Suzukis on UK roads for there to be a Suzuki guru out there -- I don't know -- so maybe a very sharp all-makes or Japanese-only shop could be found. It could be the case that the failure message is being logged by the system, and anyone with a decent scan tool could then find it even when the light is not lit.
Or, and this is not ideal but might be an option, you could wait until the airbag light comes on and stays on, then even an incompetent main dealer shop almost couldn't avoid fixing it properly...
In any case good luck. Intermittent faults can drive one mad.
11 Jul 2024 15:05 #256738
by mbethel90
Replied by mbethel90 on topic Passenger airbag
Ok so does anyone know where i can purchase the passenger airbag from ?
That “instructional video” was really helpful btw. I thought forums were designed to share useful information and not goof around
- Thank you received: 2001
11 Jul 2024 15:59 #256739
Replied by Lambert on topic Passenger airbag
I believe we have been rickrolled?
Is there a proper video explaining this or is this some obscure windup?
