Tyres
  • Goshawker
14 Nov 2010 07:37 - 14 Nov 2010 07:40 #5917 by Goshawker
Tyres was created by Goshawker
Hi I'm sure this has probably been mentioned a hundred times before and I have looked for the answer but am not to good on these forums and would be really grateful for a straight forward answer as to what is the largest tyre size I can fit on a 1999 standard jimny . I will be looking at doing a 2" lift in the new year. but just for now as the vehicle needs new tyres anyway what can I get away with. Cheers mark
Sorry should have been a little clearer there I meant without cutting arches and stuff. Also I'm lookin at probably insa turbo sahara tyres as a rough guide
Last edit: 14 Nov 2010 07:40 by Goshawker. Reason: Not correct info
  • adamjimny
14 Nov 2010 15:09 #5922 by adamjimny
Replied by adamjimny on topic Re: Tyres
my best mate has put 198/80/15 on his no problems. he is in same boat completly standard for now but bit by bit.
  • Reloaded
14 Nov 2010 15:28 #5923 by Reloaded
Replied by Reloaded on topic Re: Tyres
I've got 195/80/15 KL71s. They went on when the car was still on standard suspension and they just cleared everything ok. No need to cut anything and when you do go up 2" they'll still look bob-on.
  • ooky_123
14 Nov 2010 16:24 #5924 by ooky_123
Replied by ooky_123 on topic Re: Tyres
Depends what you intend doing in the car before you put th elift on... you can fit a 215x80 on but you will tear the ass out of your arches if you go laning without a lift.
Personally I would put an agressive set of 205's on ... maybe even go for some 235's .. the type of tyre you go for will also affect the size you can fit .. eg .. 215x80 AT2's are smaller than Diamong Back Mud tyres as the diamond backs have larger tread blocks ... mine are 29" diameter ... but my set of Dunlop AT's in teh same size are, side by side, almost 1.5 inches smaller !!!
  • biggaz
15 Nov 2010 14:34 #5944 by biggaz
Replied by biggaz on topic Re: Tyres
Im the same, standard jimny at the moment but 15x7 steels and 215/75/15 bfg mud terrains on order. Should be ok till the 3" LIFT goes on.
  • mkay
26 Nov 2010 18:26 #6533 by mkay
Replied by mkay on topic Re: Tyres
iv just put 215/65/16 on with no difficulties
Time to create page: 0.189 seconds
