A/C
25 Nov 2015 09:25 #157166 by Halford
A/C was created by Halford
Hi guys, a numpty question, believe it or not this is the first car I have had that has A/C.
How often does it need re-charging (if that's the correct term).
Car is 2007 and never been done yet, A/C works but whether it's efficient or not I have no idea.
Thanks
  • Zee Zee Top
25 Nov 2015 09:44 #157168 by Zee Zee Top
Replied by Zee Zee Top on topic A/C
I was told "when it no longer blows cold", but I leave it up to the service guys. Apparantly it is important to run it as least once a month to keep everything moving. I never turn mine off though. In the summer it keeps things cool and in the winter it keeps the interior dry. I know a lot of people say it doesn't work at low temperatures but it seems to do the trick.
  • fozzie
25 Nov 2015 10:52 #157171 by fozzie
Replied by fozzie on topic A/C
Halford wrote: Hi guys, a numpty question, believe it or not this is the first car I have had that has A/C.
Hi Halford,
My car is also 2007. I had my air con serviced soon after I bought it (last December). It definitely needed topping up. It is important to have it serviced regularly, I always had the air con serviced every two years on previous cars and will do the same with this one.
It's best to get it serviced at a place that doesn't just top up the gas/liquid. What a reputable garage/service indie would do is empty your system completely, weigh what came out, then add the correct weight of refrigeration liquid and oil into your system. The oil is the important bit as the compressor needs oil to keep it from wearing out. If you've never serviced it before, your compressor oil is 7/8 years old. You wouldn't want oil that old and worn in your engine!
I can't really remember, but I think it only holds a a couple of hundred grams of refrigeration liquid and my car was down to about a quarter of that amount.
I would recommend that you have it done as soon as you can afford it. It's not just how cold it blows but what damage you could be doing to the compressor.
Hope this helps.
Paul
25 Nov 2015 12:46 #157174 by Halford
Replied by Halford on topic A/C
Thanks Paul for an excellent informative post
Will get right onto it
  • Daniel30
25 Nov 2015 12:55 #157175 by Daniel30
Replied by Daniel30 on topic A/C
Paul.....How much is air con service then is it arms and legs :blink: :)
  • fozzie
25 Nov 2015 13:47 #157177 by fozzie
Daniel30 wrote: Paul.....How much is air con service then is it arms and legs :blink: :)
It does cost a bit, about £50 from my local indie. You can get it done a lot cheaper, but they tend to just top up the refrigerant. I find it's better to have it done by somebody who knows what they are doing. I believe they also put a dye in the system that will show any leaks.
The wife's Corsa is now 3 years old and I had that done at the same time as the Jimny. Her car was fine, but they still took the refrigerant out and replaced it with new oil.
It's true that you should use it as much as possible as that stops the seals on the compressor drying out and the precious gas from escaping too soon.
I'm no expert on car A/C but I have listened to those who do this for a living and trust they have given me the correct info.
Time to create page: 0.092 seconds
