Rumbling noise ? Differential ?
- John_S_RAA
10 years 11 months ago #156856
by John_S_RAA
Rumbling noise ? Differential ? was created by John_S_RAA
Friday 13th Jimny loaded up and on the road at 7.15am. Destination Walters Arena to help marshal at the AWDC Driven To The Edge. Once onto the A34 noticed a slight noise from drive train. Not a constant wheel bearing starting to fail noise. Rumble increases in pitch then decreases. Difficult to put into words. Drove all the way to Wales, spent 3 days driving around the site then returned home to North Hampshire. The noise is now getting louder. Today I removed the rear prop shaft and replaced it with a spare unit I have. The noise is exactly the same. Is this noise the result of a differential bearing starting to give up ? Topped up diff oil. Was a bit low but still oil in there. Has anyone else ever come across similar. Appreciate your comments on where to look next.
- John_S_RAA
10 years 11 months ago #156858
by John_S_RAA
Replied by John_S_RAA on topic Rumbling noise ? Differential ?
Oh forgot to say my Jimny is a 2000 model with over 100k on the clock. Transfer box oil level was also checked and is fine.
10 years 11 months ago - 10 years 11 months ago #156864
by facade
Replied by facade on topic Rumbling noise ? Differential ?
Mine had a noise from the rear diff. Even got a proper mechanic to sit in the back and diagnose it: he said to put some magic potion in and ignore it until it got too noisy to stand. :whistle:
I swapped the diff out and the "new " one had the same noise. :evil:
Some time later I found that the brake pedal had to be pumped to stop the car, when I jacked it up the front passenger wheel was hanging off, so I fitted a new front wheelbearing and all the noise from the rear diff went. :pinch:
Doesn't mean that your diff isn't worn, but worth checking all the wheelbearings first before you swap it.
Last edit: 10 years 11 months ago by facade.
The following user(s) said Thank You: John_S_RAA
- John_S_RAA
10 years 11 months ago #156920
by John_S_RAA
Disconnected the rear prop shaft at the transfer box. Jacked up front onto axle stands. Started up with front wheels driving. No noise. Still points to rear diff I think !
- mickt
10 years 11 months ago #156934
by mickt
Replied by mickt on topic Rumbling noise ? Differential ?
As you have axle stands use them to support the rear then run car in 2wd in gear and listen with a stethoscope or even a long screwdriver on the diff case and listen for the noise. A bearing growling should be evident.
- John_S_RAA
10 years 11 months ago #156951
by John_S_RAA
Yes I did that yesterday. Got a good stethoscope. Trouble is interpreting the noises. Thanks for the idea.
Time to create page: 0.096 seconds
