which coolant type do you use?
- jim
11 years 1 week ago #156023
by jim
which coolant type do you use? was created by jim
I have been reading up on coolant but it's not clear which colour or type is specified.
I bought the blue silicate 50/50 ready mixed with 2 year life but I'm reluctant to use it. Now I think the OAT red stuff with 5 year life is better suited.
The stuff I have in at the moment looks green but I was going to flush it anyway. Halfords didn't have a green coolant otherwise I would have just done like for like.
Thanks
Thanks
11 years 1 week ago #156029
by Rhinoman
Replied by Rhinoman on topic which coolant type do you use?
OAT is what I have in mine, if you change the anti-freeze type then make sure that you flush the system through properly first. The two types don't mix well.
The following user(s) said Thank You: jim
- jim
11 years 1 week ago #156033
by jim
I think I will go for the OAT, the green stuff in there now must be oat but I will flush it anyway.
Replied by jim on topic which coolant type do you use?
Rhinoman wrote: OAT is what I have in mine, if you change the anti-freeze type then make sure that you flush the system through properly first. The two types don't mix well.
11 years 1 week ago #156069
by Bosanek
Replied by Bosanek on topic which coolant type do you use?
Two local Suzuki dealers told me that Jimnys use "G11" coolant. It is usually blue or blue-greenish in color.
Suzuki's original service manual says that a "glycol-based" coolant should be used. It does not specify the exact technical type.
- fozzie
11 years 1 week ago #156071
by fozzie
Replied by fozzie on topic which coolant type do you use?
Weird one this. I can't find what type to use in the handbook for the car. However, my car is 2007 and was bought from a Suzuki main dealer and is filled with the Red/Pink antifreeze.
- jim
11 years 1 week ago #156080
by jim
It is a weird one! as I've heard different accounts of using silicate, oat, phosphate or even one that was phosphate and silicate.
Maybe it doesn't matter too much but just wanted to be careful as I don't want to harm the materials the cooling system is constructed of. Either way I will be sure to flush it well as mixing can cause congealing and block the system.
Halfords compatability chart recommends OAT too.
fozzie wrote: Weird one this. I can't find what type to use in the handbook for the car. However, my car is 2007 and was bought from a Suzuki main dealer and is filled with the Red/Pink antifreeze.
