Front ABS Sensor and Front Wheel Bearing Change
20 Oct 2015 13:58 #154002 by auchenblae
I used TomDK method of getting the front offside hub/knuckle housing off as I could not get the four bolts off that remove the hub flange.
I took it off as one unit.
The grease was still there a bit dirty but still greasey.
I reckon two siezed brake calipers giving out heat on that wheel stripped the grease from the CV joint and that has caused the failure.
I now have another problem the wheel bearing is a bit noisy but no play, therefore just change it but!!!
When the garage did the kingpin bearings at 30k miles and 3 years old and the car has an ABS sensor there, they broke the head off the ABS sensor bolt.
Therefore the ABS sensor is held on by the shank of the broken bolt!
So I said disconnect it at the other end but both front ABS sensors are on one plug into the ABS circuit!
Therefore I have the hub / knuckle unit tied to the coil spring and cannot get it off the car to change the wheel bearing. Unless I try to get the ABS bolt off on the other side after 8 years in Aberdeenshire salted roads!!!!
At the moment, I may well put it into the local garage to use their heat torch to remove the broken offside ABS sensor bolt and they can do the wheel bearing, the king pin bearings are great but I may as well change them at the same time! Oh and do the oil seal on the driveshaft as it goes into axle tube.
Happy days as I cannot be bothered to use my toy gas torch on the ABS bolt.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
20 Oct 2015 15:15 #154008 by Rhinoman
That bolt broke on mine, I had to drill it out.
20 Oct 2015 16:07 #154014 by auchenblae
Ok
The ABS sensor was glued to the hub casing or whatever it is called and the bolt shank had broken flush with the surface of the assembly so as you say it needs drilled out.
The ABS sensor came away after some gentle pulling so I have the assembly on the bench but cannot find the fancy 4 pin nut tool which was in the middle tool drawer a few weeks ago before I fixed the drawer runner!!!!!!!!!!!!!!!
I bought the Meyle 33 14498 0015 CV joint and on the diff input side it has less splines than the driveshaft.
I will now go and count them
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
  • mickt
21 Oct 2015 14:18 #154095 by mickt
That sheared bolt should have been picked up at the MOT. I think it constitutes a fail!
21 Oct 2015 15:38 #154099 by auchenblae
Same garage that did the work that does the annual MOT.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.174 seconds
