front shock problems
11 years 1 month ago - 11 years 1 month ago #153582 by Halford
front shock problems was created by Halford
just thought I'd share as could be useful to others :unsure:
but when I replaced my front OEM shocks I discovered they were knackered, I was aware that something wasn't quite right with the front end after having replaced the king pins, rebalanced the wheels, fitted new track rod ends.
but wasn't expecting this ....
push them in ....... and they stay in
pull them out ....... and they stay out
:( not really sad, as loving the AVO setup now :woohoo:
Last edit: 11 years 1 month ago by Halford.
  • jim
11 years 1 month ago #153583 by jim
Replied by jim on topic front shock problems
Explains the crashy ride?
  • Statey
11 years 1 month ago #153584 by Statey
Replied by Statey on topic Re:front shock problems
I'm trying to swap mine over but coming up blank with getting them off! Any tips? Every time I try I soak the nuts in wd40.
After seeing this i definitely want to do it!
Sent from my Nexus 5 using Tapatalk
  • jim
11 years 1 month ago #153586 by jim
Replied by jim on topic Re:front shock problems
Soak them and give them a firm tap with a hammer the vibrations let the fluid get deeper. This has worked for me in the past otherwise use heat on it.
11 years 1 month ago - 11 years 1 month ago #153587 by Halford
Replied by Halford on topic front shock problems
my originals had to have their nuts ground off :pinch:
audio = (melt yourself down - fix my life)
  • gaz3359
11 years 1 month ago #153590 by gaz3359
Replied by gaz3359 on topic front shock problems
Had their use them front shocks hal !
