Smiths gauges fitting/installation...
13 Oct 2015 09:58 #153543
by BGBrit
Smiths gauges fitting/installation... was created by BGBrit
Hi all
I sent this message to www.digital-speedos.co.uk/smiths-52mm-wa...re-gauge-b-443-p.asp
I have a Suzuki Jimny 1.3cc 2009. I wish to add some working bling to the interior. Can the following products be installed on a Jimny: Smith 52mm voltmetre, Smiths 52mm electrical oil pressure gauge, 52mm water
temperature gauge, 52mm electrical analogue clock. Can you supply all the required fitments too to carry out the installation. Could you send me a list of the requirements and costings to my email address (I live in
Bulgaria so no phone) Thanks in advanced. (Tony)
Their reply...
They will fit, but you'll have to sort out the fittings...Regards Julian[/color]
Has anyone on this site fitted any of the above gauges and can you help me find a supplier for the fittings.
Thanks in advanced
Tony (BGBrit)
Their reply...
Thanks in advanced
Tony (BGBrit)
13 Oct 2015 10:08 - 13 Oct 2015 10:16 #153544
Replied by Daniel30 on topic Smiths gauges fitting/installation...
Last edit: 13 Oct 2015 10:16 by Daniel30.
13 Oct 2015 10:09 #153545
by BGBrit
Replied by BGBrit on topic Smiths gauges fitting/installation...
Thanks Danial30,
I'll check them out later today..
13 Oct 2015 19:03 #153573
Replied by helijohn on topic Smiths gauges fitting/installation...
The voltmeter is a simple fitting as is the clock. The temp gauge may simple work off the sensor but I can't say for sure on the Jimny except a lot of senders are common. That just leaves the oil gauge and I have no advice.
13 Oct 2015 19:38 #153577
Try 'car builders solution' aswell
15 Oct 2015 10:13 #153689
by BGBrit
I try too thanks Daniel30
Time to create page: 0.092 seconds
