1.6 engine conversion without using adapter kit
- GraphicX
01 Feb 2016 02:03 #161614
by GraphicX
Replied by GraphicX on topic 1.6 engine conversion without using adapter kit
he needs help positioning the cam sensor timing ring on the end of the cam shaft & i don' t know how to explain it correctly to him. been discussing via PM.
- Johnniehec
- Thank you received: 56
02 Feb 2016 14:11 #161707
by Johnniehec
Replied by Johnniehec on topic 1.6 engine conversion without using adapter kit
Hi what was the original engine in this Jimny? I thought g16bb into g13bb and/or m16a into m13a was easier than this?
Cheers
John.
Cheers
John.
- Vasile
06 Mar 2019 16:44 #204199
by Vasile
Replied by Vasile on topic 1.6 engine conversion without using adapter kit
Hello. Do you have some pictures how to instal the phonic wheel on suzuki jimny camshaft .g13bb.
- gus2000
07 Mar 2019 11:58 #204241
by gus2000
Replied by gus2000 on topic 1.6 engine conversion without using adapter kit
- Thejimnythatcould
12 Jul 2022 09:47 #244058
by Thejimnythatcould
Replied by Thejimnythatcould on topic 1.6 engine conversion without using adapter kit
Can you update how to exactly time it? Is it cam
And crank set up
To tdc? Then the line on head with the top of the tooth or the centre?
And crank set up
13 Nov 2022 12:45 #245921
by Cj540
Replied by Cj540 on topic 1.6 engine conversion without using adapter kit
Per quanto riguarda l elettronica bisogna fare modifiche?
Time to create page: 0.466 seconds
